what size car tire to run and brand.
rcvision
Posted 2010-01-22 12:49 PM (#51807)
Subject: what size car tire to run and brand.
Oakdale MN
I know there are plenty of old posts to read,but thought I would ask a new one.Maybe more people are running them and have better input and options for sizing by brand? Also what are running on the front and how do you think it compares to stock? Thanks Rick
2008 Vision Street/custom.
Teach
Posted 2010-01-24 2:51 PM (#51949 - in reply to #51807)
Subject: Re: what size car tire to run and brand.
Most folks are running the 195/65 on the rear of their Vision if they are running a cage tire. I would recommend the 185/65 instead. The 195 will rub/hit on big bumps if you are running a hitch because it is just a bit too wide. Clearance with the hitch is no more than maybe an 1/8th inch on each side which simply isn't enough. The 185 will give a little more than 1/4" clearance on both sides while running a hitch.
If you are NOT running a hitch the 195 is fine.
The down side to the 185 is you will either need to order it online or try a toyota dealer to get one (way cheaper online).
On the front I run the Avon Cobra stock size.
