Need Brake Light LED Help
Prime Power
Posted 2010-01-15 5:16 PM (#51371)
Subject: Need Brake Light LED Help
I installed some brake and turn bulbs today from here http://www.autolumination.com/3157_3156.htm and they look and work great but of course no cruise. I thought I read if I installed all 6 as leds I would be fine but they are different as the brake ones flash. Well anyone have any good ideas for adding a resistor or some nice kit that will plug and play. I have little time as I am moving into a new house with many projects. The simplier the better. Thanks
Prime Power
Posted 2010-01-15 6:32 PM (#51375 - in reply to #51371)
Subject: Re: Need Brake Light LED Help
I found some load equalizers but with the heat is there any safe place back there to wire them? Also what is the wattage of a normal 3157 bulb?
Edited by Prime Power 2010-01-15 6:47 PM
Prime Power
Posted 2010-01-16 5:22 PM (#51429 - in reply to #51371)
Well found bought some 10 ohm wirewound resistors at radio shack, parallelled them with the bulbs with the connectors under the seat. Working great. Don't know if I needed all six, but I know it works. Cruise control, normal flash for turns, and the blinking brake lights. No pics, but a happy face.
