| i know its old crap but im still getting gas fumes when on the highway, whats the best cure? |
| What gas cap are you using. I had mine replaced with the new version and have had no issues since. |
| I will try to upload a picture of my newer gas cap that works very well.
 (DSCN0540.JPG)
| warrantee item. make em replace it before the gas starts silling out. |
| Thats what I did. With the original cap I couldn't fuel up at the end of the day.
Garage would stink of gas fumes if I parked it with anything more than half a tank. |
| How do you know if you have the old or the new?
| Look at my pic, if you do not have the gasket that fits over the filler neck, then you have an old one. |
Posts: 69 Citrus Heights, CA United States | gas cap should only go on so that unleaded fuel is nest to handlebars if cap is installed backwards is will not seal properly also if you put little tang at top and turn then above is installed correctly |
Posts: 301 Buffalo Grove,Ill | Stop driving on the highway !
Sorry but it was right there ! |
Posts: 374 Tucson, AZ | Yep new style cap was the cure for me...
mike
