Posts: 725 Reno County, KS | Looking for a place to hide a toggle for one of Lloydz Nitrous kits... The safety covered three-way toggle is safe and all but will draw too much attention (especially by cops). I'd like it to be accessable from the dash. I thought about utilizing the empty socket on the dash with another 3 way rocker switch but don't know where to find one that would fit. Then it would be hidden in plain sight. Any ideas? |
Posts: 1484 LaPorte,Tx. | You can buy those switches from the dealer parts department. I filled the fourth slot with another switch that is the same as the HID switch. Mine is used for the accent lights I put on the bike...yours could be for the bottle to feed the baby...gas!! |
Posts: 1632 Jasper, MO | What VisionTex said. If you need a three way switch, just order the one for the heated grips.
Ronnie |
Posts: 725 Reno County, KS | rdbudd - 2009-12-10 4:50 PM
Thanks, that's PERFECT! I forgot about the heated grip switch! I kept thinking hazards and fog lamps... But I'll bet that one would be perfect.
Thanks guys |
Posts: 742 North Orange County CA | Don't you want a switch placed where you can access it with BOTH hands on the bars? |
Posts: 725 Reno County, KS | Tarpits99 - 2009-12-10 6:44 PM
It doesn't really matter. It's just the arm/disarm switch. The actual activation is the horn button once the nitrous has been armed. The toggle cuts the horn out and puts the nitrous solenoid in circuit. I'm all for a handlebar mounted one though if you've got any leads on one. |
Posts: 8144 New Bohemia, VA | cool situp to say the least. I'd like to see it in action, but I'd probably never make to the "extreme" part of Kansas, just the conservative parts...
I thought of relocating the switches to underside, just forward of the seat of the console. Might be a good place for the Noster switch... |
