| Does the Ness edition have heated grips/seat? Electric windshield?
Aside from the bling goodies, is it on par feature-wise with a street premium?
Or more like an 8-ball... |
| The 09 did not have the heated seat or grips, It did have everting else to my knowledge. |
Posts: 935 Rockford, IL | No heated seat or grips. However the wiring for the heated seat should be there. So you could purchase a heated seat and then switch back and forth as desired.
Keep in mind that the Ness seat is different. It has a lower profile (less padding) than the stock seat, and many folks have mentioned that it isn't as comfortable as the stock seat. The Ness seat is similar dimensions to the 8-Ball seat. Heck, might be the exact same dimensions?
I think (pretty sure) that the Tour trunk can be installed on the Ness. However I think the gap between the back of the Ness seat and the trunk is "funky". Hopefully someone will chime in and correct me if I'm mistaken.
It does have the electric adjustable windshield. |
Posts: 74 Winston-Salem, NC | The Ness Vision has chrome Ness grips, Ness pegs and Ness mirrors, a custom stitched no heat seat. I suspect the winshield is like 8-ball vision and is manually adjustable but the motor can be added. The seat on my 8-ball is same as Ness dimensions, very comfortable with great low back support. |
| Thank you very much for the replies! |
Posts: 38 Galt California | I have the Ness Vision and ordered the tourpack as well. I dont think the gap looks funky although it would look better if the tourpack had the graphics that the bike has. It does have the power windsheild.  |
