Posts: 576 , IA | put bike away a few weeks ago walk by it every day quess what today oil spot on floor under oil plug yep its leaking around it plug is tight and new washer so guess i'll have to drain it again what a pain in the arrs do the treads wear out on these things not striped or anything or maybe does hot/cold temps cause something like this |
Posts: 1340 Gainesville Fl Home of the Gators | Look at the oil sending unit before you go through all that hassle |
Posts: 576 , IA | thanks i did but its under the plug |
Posts: 41 Litchfield Park, AZ | Any thread damage to case? |
