Gatlin Tips
iluvink
Posted 2009-11-05 7:51 AM (#47043)
Subject: Gatlin Tips
Dallas, Texas
When I purchased new, back in June, I updated the exhaust and added the Gatlin Tips. I am noticing now, carbon build up on inside of the tips. Is this normal for those, or is my Vision running rich, and I should check with the Shop?
Edited by iluvink 2009-11-05 7:51 AM
Bluegill
Posted 2009-11-09 8:23 AM (#47337 - in reply to #47043)
Subject: Re: Gatlin Tips
High Ridge, Mo.
I've been hearing that we run too low of rpm's when you see this. Check out any discussion on spark plugs.
Crawford
Posted 2009-11-09 9:17 AM (#47340 - in reply to #47043)
Regina Saskatchewan Canada
As far as I know the carbon build up is normal. My bike has it, any other Vision I have seen has it and all my previous bikes had it. I don't feel that it is something to worry about.
vbbuilt
Posted 2009-11-09 12:10 PM (#47364 - in reply to #47340)
I've got the tips as well, with the same buildup, but they're fairly easy to clean.  When they've cooled down enough, I just use some paper towels, windex w/vinegar.  Soot comes right off.  I don't do frequently, but when it gets "unsightly" enough, I'll give 'em a cleaning.
 Vince.
iluvink
Posted 2009-11-09 9:34 PM (#47415 - in reply to #47340)
Dallas, Texas
Crawford - 2009-11-09 9:17 AM
Thanks. I figured cleanup was easy, but worried it was running rich.
Ploz58
Posted 2009-11-11 4:06 AM (#47501 - in reply to #47043)
Central Victoria, Australia
Gday,
i have gatlin tips on my 08, when the mechanic fitted them he said i will have a bit of work to keep them clean, as the big twin needs to run rich at low rpms, so what he was saying is it normal with those tips,
They look so good they are worth the effort
Phil
Australia
metalguy
Posted 2009-11-22 12:24 PM (#48230 - in reply to #47043)
Tacoma, WA
I noticed that they get sooted up as well. And even though the tips I made are not the factory ones, they clean up easily. Now, the set I made for my Dad's GL1800 are as clean as can be. No soot! Suprizing enough, I get better mileage than he does, even with mine sooting up.....If you are curious as to what the tips I made look like, check my sig pic-----Metalguy
Big Vic
Posted 2009-11-22 4:50 PM (#48252 - in reply to #47043)
Southeast Iowa
I use Never Dull to clean mine. It works great and doesn't hurt anything.
Bearcat
Posted 2009-11-22 5:52 PM (#48258 - in reply to #47043)
Prescott Valley, AZ
Everyday chrome cleaner has worked very well for me the last two years. Granted it does tend to be a pain in the butt to clean but the comments it gets are WELL worth it!!!!!
STARSHIP 1
Posted 2009-11-22 8:40 PM (#48272 - in reply to #47043)
Houston, Texas
I use a cone shaped wheel brush with hot soapy water....cleans right up.
devilboy
Posted 2009-11-22 9:21 PM (#48275 - in reply to #47043)
Central Florida
Never had to clean mine! Gatlin tips are powdercoated wet shiny black and are well sealed against the S1L1 exhaust. No soot no excess unburned gas as Cams, intake plate and fuel controller take care of that!
see all the posts about kevinX handy work on this forum!!!!!!!!
Digby
Posted 2009-11-22 9:23 PM (#48276 - in reply to #47043)
simple green and let it soak a bit most will rinse off.
Edited by Digby 2009-11-22 9:23 PM
