Posts: 15 Quincy Massachusetts | You can use the heel-toe shifter from a Kingpin with a very minor modification to create a heel-toe shifter on your Vision. You just need to slightly modify the shifter mount bracket to clearance the Kingpin shifter, and then it will fit right on. Adjust it and you are set to go. I have been riding it for 1500 miles with no problems. |
Posts: 8 cambridge springs pa | Long Will, Do you have to file the mounting bracket a little or the shifter? Ward. |
Posts: 15 Quincy Massachusetts | Hi
Yes you need to slightly machine the bracket for clearance.
Follow this link for a diagram, the red lines indicate where clearance is necessary.
http://mysite.verizon.net/vzeq9ctx/sitebuildercontent/sitebuilderfi...
Regards
Long_Will |
Posts: 257 Under the Rule of Jedi - Masshole | Long Will... Someone was asking about this, I was going to give him your link to the pfd file. Seems it's not working anymore. |
Posts: 388 Salisbury, NC | Long Will, All I did was move the shifter back to the 1st hole and cut a 1/4" off each end of the shift rod. Been working fine for 3000+ miles. ET |
Posts: 266 Stockton, Ca. | Any chance we can get that link working again? I would like to give it a try also... |
