| I've got a lowering link on the way from Arizona Victory. (Bob at the Tuscon location)
For those of you who have done the lowering link; how did you get at the upper bolts? Did you go through the top hole in the frame? Is there any advantage in dropping out the upper rocker arm and the shock and link so that you can change the link on a bench and get it torqued up and then put the complete unit back in the bike? Thanks. Bob. |
| Sorry I can't help. Please let me know how it works out when you get done. they told me the lower kit from the '10 Vision 8-Ball will back fit. Dave at Higgins found 2 parts different on the new models. I may not need to go there because it seems my fat butt may have deflated the seat foam and I can get both feet on the ground most of the time now. |
| Will do. I will get some pictures. Thanks
Bob |
