Posts: 222 Barefoot Bay, FL United States | Is there anyone out there making a WHITEWALL tire to fit the front of a Vision?? Or is there a matching size in another brand, Metzler, Michellin, etc., the will fit the Vision that is a WHITEWALL???
Looks great with ...aahhhh........CHROME!!!  |
Posts: 8144 New Bohemia, VA | The mystery lives on..... |
Posts: 212 Tavares, Fl | I found a whitewall tractor tire that might fit with a little work on the front end, cheaper than a motorcycle tire and a tractor tire certainly must provide more traction to the front end, other than that I could not find a whitewall that would fit, I think the whitewall would look good on this bike..... |
Posts: 8144 New Bohemia, VA | there used to be, I think, back in the older days a thing you could slap on to make any tire white wall. the last time I seen something like that though is when i was a little squirt and the tops of tires came waist high. |
Posts: 732 Western WA | witchbiker - 2009-08-29 9:13 AM
Witchbiker,
I agree, a nice whitewall pinstripe would look outstanding on the Vision. I searched for a long time before going back with a set of Dunlop E3s. You can find a ww, but it's a bias ply. I think it was an Avon? Possibly Metzler.
Anyway, I decided to wait for a bit until they make a ww radial. If you do put a ww on the Vision be sure and post a pic. I would love to see it. |
Posts: 117 Spring Hill, Tennessee | Can you, or anyone else, explain the difference in a radial tire as to a bias tire? Why would you want one or the other?
I take it our Visions came with Radials?
Thanks |
Posts: 1484 LaPorte,Tx. | Some of this information is from the Dunlap Tire Website.
Bias-ply
A type of tire construction utilizing plies that run diagonally from one bead to the other. One ply is set on a bias in one direction, and succeeding plies are set alternately in opposing directions crossing each other. Sometimes called a cross-ply tire.
Radial
The tire construction utilizing plies that run radially from bead to bead under the tread. This construction requires a belt to stabilize the tread and define the tire diameter.
The Vision comes with radial tires, they are Dunlap E-3 tires.
Usually high performance motorcycles now come with radial tires. They provide better wear, better ride comfort, and better contact to the road. |
Posts: 152 Litchfield Park, AZ | Bias ply tires are made with cotton...at least they used to. The City of Goodyear, AZ was named for the Goodyear factory out in the desert making tires for the military during the war. The region was perfect for growing cotton and was also close to all the aerospace work in Phoenix.
....just some useless trivia I thought I would pass along. |
Posts: 117 Spring Hill, Tennessee | Thanks for that info VisionTex! I was hoping there was a good reason for me spending more money on the radials.
My HD Road Glide uses bias tires, but then again, its no performance machine!! LOL  |
Posts: 117 Spring Hill, Tennessee | Came up with yet another question about tires?
Can you explain the difference between these 2 sizes?
MT90B16 & MU90B16
Are these the same size tire? |
Posts: 1484 LaPorte,Tx. | No, they are not the same (width) size. The "T" is one size smaller than the "U". This is the "Alpha" tire sizing system. The Vision uses the "Metric" system. |
Posts: 117 Spring Hill, Tennessee | Is there anyway to translate "Alpha" to "Metric"?
Posts: 1484 LaPorte,Tx. | Information from the Dunlap Motorcycle Tire website. This is a very good website that has a lot of information on motorcycle tires.
Metric Alpha Inch
110/90 MP85 4.00 to 4.25
120/90 MR90 4.50 to 4.75
130/90 MT90 5.00 to 5.10
140/90 MU85/MU90 5.50 to 6.00
150/80 MV85 6.00 to 6.25
150/90 MV85 6.00 to 6.25
Posts: 222 Barefoot Bay, FL United States | Dunlap?? I thought it was DUNLOP
WHAT ??? Chrome IS a color !! |
