Posts: 129 Coastal , NJ | Has anyone installed these yet? I ordered both sets tonight and will post after I receive and install. |
Posts: 296 Central Florida | I have the fronts arriving tomorrow. I should have them on by 6 pm . I will let you know how it sounds. |
Posts: 296 Central Florida | I Installed front speakers tonight. The good news is that the sound is Excellent and is louder at a lower volume # than before. Sound is clearer and
stronger. The bad news is that the directions are worthless. Without shop manual for Vision it took me about an hour.
Now I could do it in 15 minutes. Life is a learning experience. |
Posts: 849 , FL United States | Marc,you may want to order a service manual.At $49.99 it's a good investment IMHO |
Fountain Inn, SC United States | As I understand it, once you remove the mirrors then you just have mounting screws on the front and back of the fairing for access to the front speakers. Anyone swapped the rear speakers yet? |
Posts: 1484 LaPorte,Tx. | devilboy - 2008-01-15 9:32 PM
devilboy, I'm thinking about getting these speakers, could you post some of the steps on the install, I believe I know, but not totally. I looked at the part schematic on the Victory website and it shows how the parts fit, but there is probably some tricks. Also, looks like the rear speakers are pretty easy to install. Thanks. |
Posts: 296 Central Florida | Front speakers are fairly easy when you know how.
A remove Bezel around speedo with plastic spackle knife to avoid scratching
#1 Remove aluminum front fairing 4 rubber inserts and 2 clips. DONT forget to re-connect radio antenna clip.
#2 undo large hex head bolts on each end.
#3 behind mirror is a single bolt that needs to be removed and hex head bolt for top of mirror.
#4 2 hex head bolts at front of fairing are removed
#5 1 hex head bolt is removed at inside of speaker grill on both sides.
#6 entire plastic piece covering speaker grill and plastic behind mirror comes off.
#7 Unscrew 4 bolts holding old speaker in place
#8 unplug 1 speaker lead, and plug in lead in same spade on new speaker to avoid crossing polarity
#9 unplug other lead and replug 2nd lead into 2nd spade
#10 turn on stereo and make sure that both speakers work.
#11 reverse all these steps and ride it like you stole it!
Edited by devilboy 2008-01-17 12:05 AM
Posts: 8 cambridge springs pa | I installed the J&M speakers last friday, I was a little disapointed in the sound, better than stock . But I thought it would be a lot better. Hope someone offers a plug in amp soon! Ward |
| Was also looking at these speakers. Was hoping there would be a improved sound to justify the money for them. Maybe will just keep the stock ones for now or until they blow. |
Posts: 619 Southeast Iowa | Has anyone besides devilboy or ward bought these speakers yet? I'm going to order these if they make a significant improvement over the stock speakers. devilboy appears satisfied.......ward seems a little disapointed. Any one else have an opinion? |
Posts: 423 northwest florida | has anyone looked for replacement speakers besides the J&M speakers? |
Posts: 1484 LaPorte,Tx. | I have contacted they guys, http://www.hogtunes.com/ and they are work on speakers for the Vision. Send them an e-mail, probably the more they hear from us the more likely they will produce something. J & M are good speakers also. Stock speakers are OK for most riding, not the greatest as speed. Good luck in your search and let us know the way you end up. |
Posts: 53 Ann Arbor, MI | I installed the J&M's both front & rear. Definite improvement over OEM's. Still waiting for the snow to melt so I can try them on the road. |
| I had J&M speakers on my Street Glide.....very little improvement from stock. I 'm gonna wait for another choice before I change out my Vision speakers. |
Posts: 495 Carrollton, TX | I installed both the front and rear J&M speakers on Monday. They are an improvement over the stock speakers. You get a lot less distortion at high volumes and the sound is clearer and fuller. I can turn the volume up to 28 with no distortion. After installing them I went for a test ride and took the bike up to 110 mph and I could hear the stereo strong and clear. In fact at a volume level of 25 it hurt my ears. There is a huge difference in the construction of the stock and J&M speakers. The J&M speakers have a Neodymium magnet that is much more powerful and is about three times the size of the stock speakers. The J&M speakers have an injection molded polycarbonate cone, titanium colored dust cover, and super flexible rolled edge. The stock speakers have paper cones that have been treated to make them water repellant and have no rolled edge like any quality speaker. They do have an integrated tweeter but I can’t hear where they produce any more highs than the J&M’s. All paper cone speakers regardless of how they are treated will break down and deteriorate within a year or so depending on the amount of exposure to the elements. BTW I did exchange emails with the guys at Hogtunes and they have worked with a Vision owner to try their speakers but they did not work well. They will need to get their hands on a Vision for a period of time to do the proper research like J&M has done. John the owner of J&M bought a Vision and is doing a lot of R&D on it as he wants the best for his riding enjoyment. Bottom line is I would do the upgrade knowing what I know now. The difference is not quite as much as I thought it would be but still worth the price. |
Posts: 3204 Memphis | Just FYI, Running around Texas at 110mph is fairly routine for Spock. |
Posts: 495 Carrollton, TX | SongFan - 2008-04-02 10:08 PM Just FYI, Running around Texas at 110mph is fairly routine for Spock. Texas is a huge state with a lot of wide open space. You have to drive fast if you want to cover this state in any reasonable time. Just when you think you are going fast at 110 mph a Viper, Corvette, Ferrari, Porsche or sport bike will pass you going 150 plus. I certainly wouldn’t recommend driving this fast in any of our more liberal states as they would lock you up and throw the keys away so to speak. |
Posts: 118 Capitol Region of NH | Just ordered them yesterday, I think I got a pretty good deal on e-bay, if nothing else shipping was "free". I will post again when I get them and install them. I also ordered from Powerlet a couple of outlets to add on the dash and trunk area while I have everything apart. Has anyone added outlets in these areas? My understanding is that there is wiring and plugs already there for this option. Any input on this would be helpful.
Edited by VICTORYTCRIDER 2008-04-11 9:35 AM
Posts: 296 Central Florida | you should have 2"BMW" type plugs one in glove box and one in trunk. Powerlet has a plug in adapter to go in so you can fit anything in it like a phone charger or whatever.
I have yet to use in except for using my electric tire pump to add a couple of lbs of air.
everything else on my bike is hardwired including ipod nano 3, garmin 2820 (with gxm antenna for xm radio, navigation and weather) |
Posts: 118 Capitol Region of NH | I have seen those 2 plugs. I have seen on other Vision pictures in the forums that people have one on the lower part of the center console and on the left front of the trunk for plugging in heated clothing etc. The Victory catalog says on the description for the accessory plugs that there are several places they can be put. I am just wondering if anyone who might have the plugs installed already or have taken things apart on their bikes enough to know if there is wiring in particular places already for the plug installation. |
Posts: 296 Central Florida | VICTORYTCRIDER - 2008-04-11 4:36 PM
Looking at the wiring schematic( Electrical not my specialty) there appear to be 1 extra connector location on the harness near each current connector. I have not had these areas apart myself.
I dont think schematic will tell you where they are but they are probably close to installed ones.
Hope that makes sense and/or helps. |
| VICTORYTCRIDER - 2008-04-11 3:36 PM
While I haven't had my bike apart yet to do any mounting, I have read the entire service manual for the Vision and I believe that the ports you are describing are the ports where you and a passenger would plug a helmet headset into when there is a CB/Intercom installed on the bike. I have seen a picture of the center console where someone installed an additional powerlet jack next to the headset jack and the only reason I can think of for this is what you listed, it must be for heated clothing (which would also mean that the powerlet jack should be wired directly to the battery).  |
Posts: 354 20 miles west of Chicago. | Under the plastic panel just in front of the seat there is a gray two prong ("T" pattern) plug with a Gray/pink hot wire and a black ground. It's just lying there. This is your extra Powerlet connector hookup. There is another spare connector in the trunk but I have not looked and do not know its location. This will have a Blue/pink hot and black ground. |
Posts: 118 Capitol Region of NH | Thank you all for the helpful input. |
Posts: 118 Capitol Region of NH | I have now been there. As above there is 1 plug for a powerlet outlet under the panel in front of the seat. The one in the trunk is behind the passenger backrest on the right side. I installed a powerlet plug below the right speaker cover on the trunk for the passenger to use heated clothing etc. I also installed one below the radio controls on the center console. Very quicjk and easy job with the wiring there already to go. |
Posts: 238 SF Bay Area | I just installed a set today (fronts) on my Street, to my ears they sound a little clearer at higher volumes, about the same at mid level, and not as clear at lower volumes... must be the lack of tweeters? All things considered, worth the money IMO.
Ness has a "Hawg Wired" 120 watt amplifier and crossed-over speaker (w/tweeters)upgrade kit for the Vision, P/N V-1260
Nice looking, BMF magnets, co-axial tweeters... but they are gonna cost you $749.95
| I installed a rear set yesterday and the front set today. They make a HUGE difference if you have louder pipes on your bike. The stock speakers were pretty distorted at highway speeds with louder pipes on. The new J&M's are much more clear at highway speeds. Also, the Hawg-Wired Amp for the Vision may be a while. They are still working on it. Unfortunately, the Vision's radio does not have pre-amp outputs, only speaker level outputs. If it had pre-amp outputs, there would be a lot of choices for amps. High level speaker outputs is not the cleanest (noise free) way of hooking up amplifiers, pre-amp outs are the best. Maybe some hardware guys could tap into the radio and figure out how to run some pre-amp outputs of of the radio. Tim |
Posts: 562 SC, Bluffton | devilboy - 2008-01-17 12:04 AM
#1, #2, #3, #4, #5, #6, #7, #8, #9, #10 & #11
Devilboy, thank you so much for those steps. I am ordering some Polks.
How easy is the rear speaker install? Just remove every bold head you see in the
trunk?
Thank you, Herb |
Posts: 296 Central Florida | g1nomad - 2008-06-22 1:56 PM
trunk?
Thank you, Herb
Rear is pretty simple... only have to remove 4 allen head bolts(2 left and 2 right)
also the middle pad of backrest has to come out to get at everything. I replaced my speakers while trunk was on floor. It should be MUCH easier attached to bike....
good luck Herb |
