| I downloaded a .pdf of the Vision service manual from somwhere and now I can't figure out where (thought I bookmarked it but guess not). I've got it on my thumb drive and I want to send it to a friend (my wrench) but it's too big to email. Does anyone have a link? The project is to hook up a cheap 12 volt plug under the handlebars somewhere to plug in my Valentine radar detector. If there's an easier way I'm open to suggestions ~Shy |
Posts: 8144 New Bohemia, VA | www.mediafire.com/2008visioninfo
thank david white |
Posts: 113 East Ohio | The fuse boxes are right under the front access panel, just run a line
Go Super Steel |
Posts: 725 Reno County, KS | There's also a spare accessory plug socket located under the access panel between the tank and the seat. Plugs into OEM Vic plugs. I think they run $10 or $15. |
| Thanks all. ~Shy |
Posts: 23 Fort Worth | I wish I had looked here first........ I paid $9.99 to download the service manual from tradebit:
http://www.tradebit.com/filedetail.php/8585754-victory-vision-stree...
Oh well, $10 is a lot cheaper than buying it at the dealer and tradebit downloaded the manual in less than 10 minutes vs. an hour for the mediafire download.
Posts: 208 Wichita, Kansas | Wow. On a new computer tonight and the mediafire downloaded in a little over a minute on my DSL.
Anyway, the two gray powerlet plugs under the console will also accept standard 1/4" male terminals and are protected by a 20A fuse in series with the horn relay contacts. That makes for a great accessory bus. |
Posts: 135 Yellowknife, NT Canada | Is this manual still available online? |
| This is what I wanna know as well. It appears to have been moved or removed. I can't access the service manual link anymore either. Anyone know??? |
