Posts: 129 Coastal , NJ | Lloyd gave her back today....man it felt good to ride. Throttle response is GREATLY improved and my 70 mile trip home at 75-80mph returned a 41 mpg average...Nice!! |
Posts: 495 Carrollton, TX | Are you still running the stock pipes?
Was the first dyno run with everyting stock?
That is a nice gain at the rear wheels. I'll bet the bike isn't running as lean anymore and should run cooler and it looks like the gas mileage didn't suffer.
Craig
2008 Vision Tour Premium on order. (Midnight Cherry) |
| Fantastic, I wish I could fly him out here to do his magic on my JP, I feel like I've lost all my top end.. |
| Luzzy,
What do the 2 graphs represent? They are not identified what is what?
Pipes?
AirBox Mod?
VFC?
Remap/Downoad?
Combination of the above?
Thanks,
Tim |
Posts: 129 Coastal , NJ | My bad...I assumed everyone knew from prior threads.
First run is with Stage One Level One pipes only(no performance filter or download)
2nd one is with lloydz VFC and Vision airbox mod shown |
Posts: 3006 San Antonio, TX | Luzzy,
Where does the air box mod install? |
| So Victory is way overrating the HP and torque for the stock Vision, looks like the Vision with Lloyds improvements and stage 1 pipes are right at the stock #'s Victory boasts on the website. |
Posts: 495 Carrollton, TX | When Victory or other manufactures list horsepower and torque ratings they are from the engine crank not the rear wheel as the Dyno that Lloyd is using. There is usually a 10 to 15 percent loss in transferring power to the rear wheel so the increases Lloyd got are pretty good.
Craig
2008 Vision Tour Premium on order (Midnight Cherry)
tralphaz - 2007-12-30 1:13 PM
Fountain Inn, SC United States | radioteacher - the intake plate mounts to the front of the intake (where the stock air filter is). The plate uses a different K&N (conical) filter -shown in Luzzy's photo. |
| JAM - 2007-12-30 6:47 PM
JAM,
I thought it mounts to the access panel on the top of the airbox?... thus having 2 air intakes and 2 air filters.
Tim |
Posts: 1324 So Cal | Where did you mount the VFC control panel? Is it hidden or accessable when riding? |
Posts: 296 Central Florida | Looks like it is under panel right below instrument panel. That painted panel can be popped off when you open gas filler and glove box.
access is simple |
Posts: 293 Arkansas | For sure the intake plate from Lloydz mounts to the top of the frame under the console independent of the K&N. I talked to Lloyd yesterday about it. |
Fountain Inn, SC United States | I stand corrected! |
| Spock - 2007-12-30 11:47 AM
Craig
Interesting, According to Kevinx one of the resident Vic experts at the VMC, he claims it's at the wheel.
http://forums.thevmc.com/megabbs/forums/thread-view.asp?tid=42225&p... |
Posts: 47 Adamsville, Tn | The Vision brochure says 92 hp and 109 ft-lbs torque at the crank. |
Posts: 129 Coastal , NJ | Sorry Guys,
Was a bit under the weather the past couple of days.
The Filter Mod is under the center console and cleans up the air very close to the intake.
The VFC is located under the Panel Close to the seat. Pop it off, make adjustments ...easy.
Factory always rates at the crank(looks more impressive) - So the numbers Lloyd got represent almost a 10% gain in HP....nice.
It's nice to have her home.
| luzzy - 2007-12-29 1:37 AM
Luzzy,
It looks like it takes all 3 of these mods just to move the factory crank numbers 92HP/109 Ft-Lbs Torque to the rear wheel. That is some drive train loss.
Tim
Edited by TimS 2007-12-31 6:27 PM
Posts: 296 Central Florida | FYI anyone waiting for the Stage 1 Level 2 pipes, keep waiting!! Feb 15th is new date, so we are stuck with level 1 pipes or nothing.. |
| I guess I'm just surprised that a basically stock 106 inch is dynoing at #'s that many stage 1 92 inch owner are claiming to be getting. |
Posts: 495 Carrollton, TX | According to the dyno runs that Lloyd has done on the 92 inch with a stage one you get 70 hp and 90 torque and with effectively a stage one on the Vision 106 you get 94.65 hp and 110.51 torque. That is a pretty good increase and this is with the stage 1, level 1 pipes. The stage 1 pipes for the 92 are more like the stage 1, level 2 pipes for the Vision and we need to wait to see what difference they will make when they are out.
Craig
tralphaz - 2007-12-31 8:29 PM
Posts: 223 Valdosta, GA | On my Jackpot, it took aftermarket pipes, the PMRT airbox, and the VFC to see 94/105 at the wheel. A Stage 1 92" motor is not seeing those numbers...
On an aside...With Lloydz filter installed, is the K&N necessary or can it be removed? I know it's doesn't provide much flow restriction, but as they say, every little bit helps. Also, what does the air channel in the frame look like? Could there be some benefit from polishing or is it already pretty clean?
Posts: 1484 LaPorte,Tx. | Mike, Most dealers that have websites have an online parts catalog, on this you can see some of the parts on the frame and at the filter. According to this there is a what looks like velocity tubes (4) assembly right after the filter that should help straighten the flow. The tubes though don't look very long. |
Posts: 223 Valdosta, GA | The part catalog is posted on Vics website. I just took a look and sure enough, there is a tube setup in there. Unfortunately, it just not a clear picture of what is going on inside ther. I guess I'm gonna have to take it apart and see what's what...
Posts: 177 NW Illinois | Can you list the parts you added along with price of each |
Posts: 129 Coastal , NJ | graybeard - 2008-01-13 7:36 PM
Click on the links tab at the top of the page. Then click on Lloydz. All the info is there. |
Posts: 177 NW Illinois | Will do thanks |
| Here is another set of dyno readings for comparison. The Motorcycle USA plots are supposed to be of a Victory Vision with Stage 1 pipes. At the rear wheel from Motorcycle USA: 84.4HP and 94.9 ft/lbs of torque At the crank from Victory: 92 HP and 102 ft/lbs of torque
Horsepower  Torque
Edited by TimS 2008-01-22 5:14 PM
Posts: 223 Valdosta, GA | Is that with a full stage one kit or just the slip-ons? I would think the addition of the filter and remap would do quite a bit more for that 106... |
Fountain Inn, SC United States | The VFC is now available here:Lloydz Mini Store |
