Posted 2009-05-18 6:34 AM (#34861) Subject: Gatling Tips Tip
Posts: 257 Under the Rule of Jedi - Masshole
Here's a little tip for those of you who have dirty Gatling Tips on your pipes. An easy way to clean the soot is to use carb cleaner. Just be sure to spray it on the rag and not around the bike. IT WILL REMOVE PAINT!
Posted 2009-05-18 10:18 AM (#34874 - in reply to #34861) Subject: Re: Gatling Tips Tip
Posts: 203 Rapid City, SD
I use some of the metal polish and some 00 steel wool. The combination of the two makes pretty quick work of the soot without worrying about paint removal.
