Picture of Stage 1 Level 1
VisionTex
Posted 2007-12-14 5:41 PM (#3006)
Subject: Picture of Stage 1 Level 1
LaPorte,Tx.
I picked up my Stage 1 Level 1, thought I would post some pictures, they are in my gallery. Plan on putting it on when the break-in period is over.
DesertJim
Posted 2007-12-14 5:45 PM (#3008 - in reply to #3006)
Subject: Re: Picture of Stage 1 Level 1
Scottsdale AZ
Tex, you'll love em, put mine on a couple weeks ago. Don't tell but I also took out the EPA baffler, I think I get a few more HP.
BUCKEYE
Posted 2007-12-14 8:32 PM (#3021 - in reply to #3006)
29 Palms California
shhhhh, he took out the baffles...mums the word...HUH? Can't hear you, your pipes are to loud.
cjnoho
Posted 2007-12-14 9:03 PM (#3025 - in reply to #3006)
So Cal
V-twins 101 has a little display with the sounds of, stock, level 1 & level 2 recorded. You push a button and you can hear each as they pull away. I really cant tell the diffrence between the two levels. What I like about level 1 is that if you get a scratch or a dent you just replace the cover. I know the pipes are high and the chances of hitting them are slim but fate has a way of finding me.
devilboy
Posted 2007-12-16 10:23 AM (#3071 - in reply to #3025)
Central Florida
Level 1 Stage 2(if they ever deliver them) are 40 lbs lighter and are one piece without heat shields to rattle.even if they dont provide a better sound, the loss of all that weight should help performance.
cjnoho
Posted 2007-12-16 1:48 PM (#3077 - in reply to #3006)
So Cal
I think Ive decided on the stage one level 2 exhaust. Its only $150 more than the level 1. I dont see needing any more performance than that. If I add a power commander or VFC 3 I'll just want to go for more. I fell into that trap with the HD.
devilboy
Posted 2007-12-16 10:57 PM (#3106 - in reply to #3006)
Central Florida
Lloydz has a VFC gen 3 coming shortly as well as an intake set up to calm down turbulence of air entering Motor.
these couple of things plus the stage 2 should be all I need..................for now..
last date I have heard for stage 2 is 12/31/07....
