Posts: 113 East Ohio | I wont be tearing into it for a couple days and the service manual isnt very clear, my question is, Does the radio antenna have the standard end, I will hooking up a fm direct for my xm radio, thanks |
Posts: 3773 Pittsburgh, PA | I connected a direct connection for my Sirius. it works perfectly. it is a standard GM connector. No mods needed. i gave up on the antenna. i even used the powered fm antenna and it wasnt worth a Shhhh.. so i went Sat radio.. and now i Love it!!! and better yet commerical free! it took about 5-10 mins to connect my Fm adaptor to the vision. |
Posts: 725 Reno County, KS | Yes it has a standard plug. It is a little hard to pull at first but it will free up. It is rather deep so be sure you have a long enough adaptor plug for your XM kit. |
Posts: 447 Northeastern Penna. | Hey Arkainzeye, Do you know what model FM adapter you used for your Sirius ? I checked on Sirius website, it looks like there are a couple different models, but it seems like the wiring is the same. Plug the antenna wire into the adapter, plug adapter into the antenna port on stereo, and other end of adapter into FM out on the cradle. |
