heated grip
jerrysauto
Posted 2009-03-28 10:35 AM (#31106)
Subject: heated grip
im having a problem with my heated grip. Theleft one gets nice and warm but on the right side u just can feel a little heat. anyhelp please.
norcan
Posted 2009-03-28 11:11 AM (#31108 - in reply to #31106)
Subject: Re: heated grip
Edmonton Alberta, Canada
Did you check the wiring between the grip and where it goes through to the handle bars. I have watched mine as it comes very close to to rubbing on the control pod when you twist the throtle. Only sugestion for now
Gray rider
Posted 2009-03-28 7:20 PM (#31139 - in reply to #31108)
Tucson, AZ
I have just the opposite problem. My right grip is warmer than the left one. I'll have to check the wires.
Posted 2009-03-30 10:44 PM (#31321 - in reply to #31106)
get this.. today i went for a ride. turned off the bike. then turned it back one 20 mins later... NO HEATED GRIPS.. i was like... ok what just happened.. i checked fuses.. Nothing.. so then i got mad and decided i would take the powered antenna off the bike since it never worked anyways.. well then i removed the console and discovered one of the wires that leads to the heated grips Switch came loose and fell off. so i pushed it back on and all is good!
