Posts: 212 Tavares, Fl | I replaced the rear tire today and had one heck of a time adjusting it. The manual states to run the tire forward and adjust the belt to the inside of the sprocket and adjust till the belt moves outward when rolling the tire backwards... I did this but the allignment marks are off quite a bit. Has anyone else done this????Is there a better way?????? |
| My bike had "chirping belt syndrome" when I bought it. I aligned the belt by the manual (just like you did) no more chirp. The alignment marks were not the same. I have never owned a motorcycle that the marks line up perfectly. This is due to manufacturing tolerances. Go with what works, not the marks. |
Posts: 212 Tavares, Fl | Thanks |
| It's really too bad Victory didn't do the same thing that Harley does on the newer models for rear belt alignment, they have an oblong washer welded on the axle bolt, the other end has a grove or notch cut into the axle where another oblong washer is seated so they basically act like a cam, alignment is perfect every time only have to worry about tension, turn the axle bolt bolt and both ends than turn at the same time thus putting more or less tension on the belt, not sure what year they stated doing this but my 2006 had it have a 2008 now, makes rear tire changes a breeze,
VICTORY TAKE A GOOD LOOK AT A HARLEY YOU MAY JUST LEARN SOMETHING HERE,
OH I ALSO HAVE A VICTORY VISION SITTING IN THE SHOP!!!!!!!???????
Posts: 156 dinwiddie, va | I agree. I love adjusting the newer hds when they come in. It is a very good idea. But i think HD is the last company victory needs to take pointers from!!! If they did that, we would be living in the 70's again! |
Posts: 447 Northeastern Penna. | What brand tire did you replace the rear tire with ? Also, is anyone else experiencing a howling sound from the stock tires. I would say from the front, when you are cornering, the sound becomes evident. I have about 8500 mi. on the bike with even wear on the tires, it's just the sound. |
Posts: 1632 Jasper, MO | Yep, the howling sound in the corners is the nature of the Dunlop E3's. They do it on the Goldwings too. It's irritating, but I went back with the E3's anyway, since they were readily available when I needed them.
Ronnie |
Posts: 1632 Jasper, MO | tjjtande11 - 2010-03-22 11:31 AM
It is a good system. Harley copied it from the Japanese and European dirt bikes. Even my old Husqvarna has it.
Ronnie |
| wjoel, I'm running the Avon Cobra's on mine. At first no howl like on the E3 but now I'm beginning to detect some sound. I think it is one of those radial related noises and not just something common to the E3. I do prefer the feel of the Avon over the Dunlop |
Posts: 447 Northeastern Penna. | Thanks, that is one option, other than the Dunlops. |
