Posts: 7 Herriman, UT United States | I am re-born into motorcycling. Back in the Air Force days of the 80's. Briefly dabbled with riding again in mid-90's. Back in May bought my dream bike. Victory Vision!
Time to replace brake pads.
Recommendations?
I found these options at 2 locations. More are available I am sure.
https://www.jpcycles.com/2014-victory-vision-tour/brake-pads
https://buywitchdoctors.com/c/294/victory-vision-brake-pads-accsys-s...
Thank you in advance for your suggestions.
Edited by Vetrepreneur 2018-09-25 8:09 AM
Posts: 1632 Jasper, MO | It looks like there are plenty of choices. I replaced mine, on my 2008 Vision, with OEM Victory pads. I realize that may not be an option now.
Ronnie |
| Sintered metal will stop you quite a bit faster then oem. EBC and Lindall are high on the list of good pads.
I like oem for the rear cause there thicker and you use the rear a lot to slow down.
Make sure you take the metal perforated backs form the old ones and put on the new pads they quiet the pads.
Aftermarket stops 100% better then oem
look at Dennis Kirk free same day shipping |
| The EBC pads put some pretty heavy wear on my rotors.
Just replaced the front rotors and went Lindall all the way around. The Lindall rear pads bear a very strong resemblance to the OEM pads.
According to Lindall, they don't cause wear on the rotors. We'll see.
Disclaimer: replaced rotors had 133Kmi on them.
Edited by BumbleDB 2018-09-25 9:57 PM
