Posts: 8 Toronto, ON Canada | So with Victory Vision accessories becoming more and more difficult to find, I notice the cross bike community has enough popularity to develop a really good swap shop on a couple of sites. I'm curious about what will fit and what will not... Seats will not, front fenders will but attachment for the rear support has to be fabricated. I don't know about the x 1, 21 inch front wheel, As far as I know most engine components are the same, but exhaust mufflers are not... - Mal |
Posts: 1632 Jasper, MO | The Vision comes pretty well equipped. What kind of accessories are you looking for?
The engines are the same. There are lots of muffler options from the aftermarket, not even counting the old tried and true Thrush muffler. The aftermarket has seat restoration and customization already covered.
Ronnie |
Posts: 28 Mossyrock, WA | Heated grip kit. My 09 Arlen Ness did not come with heated grips. I purchased a kit for a kingpin/jackpot #2876289. Fits right on! The wiring to the rocker switch is a little long but so what. Worked great. |
Posts: 28 Mossyrock, WA | Exhaust mod with Magnaflows mufflers. There is a YouTube vid of a guy with a CCT slipping in glass packs after cutting the end off his mufflers. Well the Vision's are a 1/16" smaller in the I.D. than the CCT. Had to split mine down the side also to fit the Magnaflows inside. I did a friends CCT after mine and his slide right in. Just a beware if watching internet vids. |
| cross bikes and vision use same belts and brake pads. Exhaust header pipes are the same so is the battery.
No body parts including front fender with out adaptor. No windshield or radio. Yes grips and stock wheels will fit.
Both motors use same oil and oil filter along with drain plug ( get a honda drain plug there better)
Calipers are the same kickstand are the same. Brake lever is came up to 2015 then vic got cheaper and did away with adjustable lever
 (drain oil.jpg)
drain oil.jpg (81KB - 2 downloads)
Posts: 73 San Diego, Ca | Why is the Honda plug better? |
Posts: 8 Toronto, ON Canada | I'm pretty sure they're magnetic |
| On my 08 Vision..I got a Porkchop puck.....an extension and replacement for the kickstand pad...and a magnetic oil drain with a 9/16 head...so much easier then an Allen head.....for mufflers Drew Miller sells Vision slip ons that come in 3 baffle types standard (louder than stock) mid, and non baffled....he charges 400 shipped with a 100 core on return of your stock exhaust...shipping paid.....I'm contemplating purchase now |
