| I am in search of a full wiring diagram for a 2009 Victory Vision. I have an intermittent problem where the instruments, radio, etc. loose power, but the bike will run and has headlights. I can't find a common cause, but I recently noticed that sometimes I can simply switch the bike off to the accessory position and back on, then the power returns to the instruments and radio, etc. |
Posts: 10 Edendale New Zealand | NCRYDER,
https://www.mediafire.com/folder/aoq581k2ab25z/Victory_Manuals
Try this link, I downloaded a service manual from here for my 2008 Vision. I cannot see one for a 2009 but I would imagine there would not be many changes between the two.
Rob |
Posts: 48 huntington In. | My bike does the same thing. Check the switch. If I wiggle the switch everything comes back on |
Posts: 36 , IL United States | mine does the same thing occasionally. Wiggle the key switch position does the trick. I suppose you could replace the switch. |
Posts: 43 Rossville, IL | Mine sometimes too, usually after coming out of winter storage. I can always tell as the key gets harder to pull out and it doesn't click through the detents when turning it on. I suspect it gets a little corrosion from water getting in it from either rain or washing it. I use my trusty Kano Kroil and stick the spray tube down in to the keyhole and give it a little squirt. Slide the key in and out and rotate it a few times and it's good to go for the season. |
| Thanks for the responses, I will check my switch and the diagrams in the service manual. |
Posts: 3773 Pittsburgh, PA | I just read about someone with a 2012 ness vision that has the same problem . And when he wiggled his key it woukd work ... for him it was his ignition assembly .. |
