| 2012 vv with 25k on it. when going over a big bump sounds and feels like the rear end is falling off,also seems like its trying to jump a tooth on sprocket |
Posts: 154 Danbury, Connecticut | Take a look at the shock mounting bolts, the pivot on the top, between the shock and the link, and the link mounting hardware. Sounds like something may be loose there. You can see the pivot with the seat removed. |
| pull seat and look at rocker arm. there is bearings in rocker arm they could be bad
or the pin itself could be bad.
http://parts.polarisind.com/Assemblies.asp
 (10VN.gif)
| thanks for input i`ll check it out. there was no air in shock ;but that shouldn`t cause it to BANG over some bumps;it don`t sound good |
| put air in shock and see if clunk goes away
| yea i will if the weather ever gets above 50 degrees. 2012 victory vision tour tan trunk removed, witchdoctor exhaust. love bike except for rear end noise |
