Posts: 394 Tucson, AZ | Does anyone out there have this exhaust? If so, how do you like it? Of the ones I've heard on the Utube videos, I think these sound the best. Also I've thied to find a site with more information, but have been unable to locate one.
Any help is appreciated.
2008 Steel Gray tourer comfort pkg. |
Posts: 412 Fargo, ND | If you haven't been here, you may find some valuable info... http://www.vision-riders.com/bb/forums/thread-view.asp?tid=1598&start=1&highlight=Atom+Bomb+Exhaust&highlightmode=1 Good Luck! |
Posts: 935 Rockford, IL |
They are only available thru this Ebay seller...nowhere else.... http://cgi.ebay.com/ebaymotors/Modifiy-your-Victory-Vision-Mufflers... |
Posts: 3773 Pittsburgh, PA | yeah i seen him selling them on ebay.but there is no info on turn around time etc.. |
Posts: 394 Tucson, AZ | Thanks for the feed back. Now I want to know about remapping. Necesary? I would assume so. If so, do you just a new map from Victory? |
Posts: 935 Rockford, IL | Gray rider - 2009-01-04 5:57 PM Thanks for the feed back. Now I want to know about remapping. Necesary? I would assume so. If so, do you just a new map from Victory? No remap needed Arkainzeye - 2009-01-04 5:40 PM yeah i seen him selling them on ebay.but there is no info on turn around time etc.. Turn around time is fairly quick. I told the Bob to take his sweet time on mine 'cuz I didn't need them for at least two months. I paid him the begining of this past week and I received an email today saying I should have them on my doorstep by this coming Wed.
I would think if you did happen to need a quick turn-around all you need to do is let him know and I'm sure he will take care of ya.
Edited by Lotzafun 2009-01-04 7:02 PM
Posts: 3773 Pittsburgh, PA | so if you leave the stock air filter in there you should NOT need remapped? i ask cause i was wondering about a decrease in back pressure.. see im not really looking for more power, im looking for sounds.. but i dont want to loose any power either from a decrease in back pressure and me not remapping.. this is really interesting to me.. thanks for any and all info |
Posts: 3773 Pittsburgh, PA | that would be so great to install them atombombs with out having to install a NEW map.. cause at this point im not looking for more power. just nice sound! ya know? that would be just great.. $200 + without having to buy a KIT at over $500
Lotzafun - 2009-01-04 6:59 PM
I would think if you did happen to need a quick turn-around all you need to do is let him know and I'm sure he will take care of ya. |
Posts: 935 Rockford, IL | No remap or anything needed if changing just the exhaust. However there is a chance that a slight case of poping/backfiring on downshifting/de-accellerating may happen. If its minor there don't worry about it. If it is a bit major (which I doubt) then a fuel controller can take care of it.
Now the next thing is to keep in mind that I'm going with a bit of limited knowledge. I mean I'm fairly confident with my answer, but not quite 100% though. I guess I'm answering in that as far as I know when replacing a muffler on a closed-loop system nothing else is needed.
Well...hopefully someone with same or more knowledge will step in here and confirm or adjust or show me wrong. |
Posts: 3773 Pittsburgh, PA | Hey Lotzafun, did you say you are getting the atombombs? if so can you share with me whats involved in removing the stock mufflers? What needs removed in order to remove the mufflers. |
Posts: 175 Hinton, Iowa | Lotzafun - 2009-01-08 12:28 PM
I have stage 1 level 2 exhaust now. Can I run this exhaust with the map I have? or do I have to get a remap or fuel controler?
Ride safe, Mike |
Posts: 3773 Pittsburgh, PA | hey airguy i was wondering something of the same.. if you get the atombombs and since they are louder which victory map would you use if you have a high flow airfilter? stage1 level 1 OR stage 1level 2, which area does the AB's fall into? I want to run them in stock form, but when the time comes to replace the air filter id like to get the higher flowing K&N and then i would need remapped. but which map? |
