Posts: 222 Barefoot Bay, FL United States | Can anyone tell me the actual dimensions of the Vision handlebar? I know it's a bit of an OVAL shape, but I'm looking for a RAM mount clamp for a Sirius radio, to mount to the bar. Someone from Ram mount said they might have a clamp that will fit. The Vision is NOT listed as a motorcycle in the "Vehicle" wizard to find a mounting system.
Thanks,
witchbiker
2008 Vision Tour Premium--lots 'O chrome  |
Posts: 1158 Richmond, Virginia | I can go measure mine where do you want it measured from in case the dimension changes being that the handlebar is not completely round? on the top flattest area?? ... ok just ran out into my 28 degree garage for you
1. the area of handlebar just off from the brake fluid res but not turning down into the housing is 4 3/4 (if you want your mount
at the top and on the only flat available space
2. 4 1/2 down the center of the handlebar about 3-4 inches from the top bend.
hope that helps |
Posts: 231 Hampton Va | I mounted mine to the dash..... works well there ... there are some pics in the gallery if you are intersted |
