CLUTCH Disc replaced.
TRELL
Posted 2016-05-29 1:51 PM (#184235)
Subject: CLUTCH Disc replaced.
Got 52k on my 2011 vision needs clutch replaced. My question is can the plate be pulled out and new ones installed WITHOUT pull the clutch basket out of the bike? Someone told me to lay the bike over on the tipovers and pull only the clutch plate out and not pull clutch basket. The service manaul says different.
Posted 2016-05-29 6:33 PM (#184241 - in reply to #184235)
Subject: Re: CLUTCH Disc replaced.
first drain oil. Then you'll need a clutch spring tool. Harley aftermarket shop might rent you one. you can buy one. Yes you can pull plates BUT go slow so you get everything back in same order. Lips on metal and fiber plates are crushell. There is a 2010 service manual here that should help you.
http://www.ebay.com/itm/Motion-Pro-Clutch-Spring-Compressor-Tool-08...
get barnett plates from witchdoctor. read how to soak the plates in oil before instal
https://www.mediafire.com/folder/aoq581k2ab25z/Victory_Manuals
Posted 2016-05-29 6:43 PM (#184242 - in reply to #184235)
this would be the same for your bike
https://www.youtube.com/watch?v=r2gej1pO3Lw
TRELL
Posted 2016-05-30 2:58 PM (#184297 - in reply to #184241)
That tool on ebay seller says won't work on victory vision...
Posted 2016-05-30 4:57 PM (#184298 - in reply to #184235)
did you look at Kellys video he made one or here is another one
http://cyrilhuzeblog.com/2016/05/24/barnett-clutch-spring-compressi...
