Posts: 23 bowling green ky | I have an 08 vision with 30,000 on it. Atom bomb pipes flash and hi flow front air filter. I had been wanting to cam mine for a while now but was afraid i woudnt get enough bang for my buck. I pulled the trigger on a set of andrews 438 cams a power commander 5 and top air filter. This bike should come from the factory like this. It is now a beast. I should have done this years ago. Anybody on the fence about getting cams. Dont wait do it now you wont regret it at all. You will only regret that you didnt do it sooner |
Posts: 3773 Pittsburgh, PA | The you should get the timing wheel as well ! I didn't get cams yet...but holy crap that timing wheel made my 2011 vision come alive.! BTW thanks for the hEads up on the cams.. I've been thinking about those new XV-30 cams.. |
Posts: 8144 New Bohemia, VA | I appreciate this insight. I've remained stock all these years with the case never being opened. The stock Vision has always given me what I needed and more at 194,700 miles and still running strong. I'm glad you all enjoy the extra oomph. |
| My results with just cams and fuel controler
 (My Dyno.jpg)
My Dyno.jpg (82KB - 2 downloads)
Posts: 1308 Sand Rock, AL United States | Chris, please update your signature. I have been looking at the "190,###" thinking you weren't riding are something was wrong.  |
Posts: 1308 Sand Rock, AL United States | katman - 2016-05-24 6:18 PM
I have the timing wheel in my 2009 and can't imagine wanting more. I also got a surprise timing wheel in my salvage engine for my 2008. It runs ok (but nowhere near as well as Ruby86 aka the 2009 Anny) 2008 needs tuning and or reflash, I'm sure. my local tech does not have a dyno or computer to properly introduce this new engine to the fueling system.
Edited by jimtom 2016-05-25 2:45 PM
Posts: 341 West Salem, WI United States | varyder - 2016-05-25 7:27 AM I appreciate this insight. I've remained stock all these years with the case never being opened. The stock Vision has always given me what I needed and more at 194,700 miles and still running strong. I'm glad you all enjoy the extra oomph. Chris, I think thats exactly why I am only going to go with the top filter and PCV with a Dyno tune. I already have the timing wheel and that did wake the bike up a bit. I don't need much more, but want that extra lower end torque. The PCV and tune are really just to smooth out everything and get both cylinders working together at top efficiency. |
Posts: 1308 Sand Rock, AL United States | couple the quarter turn throttle ring with an ATW and you got a different motorcycle |
Posts: 251 Mechanicsville, VA United States | I've got cams,PCV,top airfilter,timing wheel, stage 2 level 2 exhaust and I've had to reduce the timing in the PCV to stop the pinging....I started out at +4 degs. on the timing wheel and zero on the PCV and it pinged, then reduced the timing wheel to +3 and it pinged, now I'm at +2 and still getting the ping so I reduced the timing on the PCV to -5 degs. and finally the pinging is gone....I think after I get back from Vacation I will remove the timing wheel and put it up for sale. I have read while the timing wheel on some Vision only work in neg.(-)degs. Having the Power Commander V allows you to adjust timing same as the timing wheel but I didn't know that before buying the wheel and you don't have to twist any wrenches just push computer buttons. |
Posts: 3773 Pittsburgh, PA | you will be the 3 or 4th person i heard that wanted to remove the timing wheel.. its strange how some bikes can have them and some just cant.. i have a timing wheel set to +4 on my 2011 vision.. i have the S1L1 exhaust, ness top and front filter. PCV with AUTO TUNE and now the timng wheel.. i have not ridden 2 up yet with the wheel.. i hope i never getting pinging.. as i LOVE that timing wheel.. the best bang for the buck !! makes me 2011 feel like i put alot more performance mods on than just timing... |
Posts: 3773 Pittsburgh, PA | diamonbird - 2016-05-26 7:17 AM
i was wondering since the pcv only allows timing adjustments from 2500 rpm and above. do you get pinging below 2500? |
Posts: 219 Pittsburgh, PA | I am with varyder, stock is what I started with and I see no reason to go after more than that. The bike is just that good. I don't feel as though I have to do any mods or power increases to it. |
| taz456 - 2016-06-01 1:34 PM
I respect that you like your bike stock, I'm not trying to blow smoke, but some of us are in the "can't leave good enough alone" camp. I wish I had grown up instead of just grown old and I did like the Vision or an Indian as is, it would be a whole lot cheaper and easier. I have cams, with all of the usual suspects (PC-V) and just recently upgraded the suspension with Traxxion Dynamics AK-20s in the front with a Penske shock in the rear. I ride with some other brands and types of bikes and I get a kick out ambushing someone who just talked smack about how fast his bike is and how well it handles. Kevin X told me Lloydz will be coming out with a turbo kit for the Vision in the near future that will bump the power into the 150HP range at the rear wheels for a cheaper price than the supercharger kit. I can't wait. |
Posts: 1632 Jasper, MO | olekneedragger - 2016-06-16 5:11 PM
Yep!! Same here. 65 year old kid at heart.
Mine is a true "sleeper" that looks and sounds 100% stock. Stock exhaust. Lloydz cams, VFCIII, top filter, and Lloydz ECU reflash. Never been on a dyno. Don't need it. The VFCIII was tuned by the road test method, which works well. We ride with good friends that ride Harleys and Goldwings. The Goldwings are the "trash talkers" around the Harleys, BUT they learned to leave my Vision alone.
The Goldwings can take the 110 SE Harleys, and I can take the Goldwings that have tried.
Ronnie |
Posts: 3773 Pittsburgh, PA | So far my timing wheel set to +2 with riding 2 up and bike fully loaded with gear did not ping when u rode down to helen Ga and back .. it was perfect ! But at +4 it pinged with just me.. when the Temps got over 80f |
Posts: 92 Moncks Corner, SC United States | Does anyone know the difference (if any) between the Lloydz cams and the Andrews 438 cams? I have the Lloydz Cams and I like them. |
| diamonbird - 2016-05-26 7:17 AM I've got cams,PCV,top airfilter,timing wheel, stage 2 level 2 exhaust and I've had to reduce the timing in the PCV to stop the pinging....I started out at +4 degs. on the timing wheel and zero on the PCV and it pinged, then reduced the timing wheel to +3 and it pinged, now I'm at +2 and still getting the ping so I reduced the timing on the PCV to -5 degs. and finally the pinging is gone....I think after I get back from Vacation I will remove the timing wheel and put it up for sale. I have read while the timing wheel on some Vision only work in neg.(-)degs. Having the Power Commander V allows you to adjust timing same as the timing wheel but I didn't know that before buying the wheel and you don't have to twist any wrenches just push computer buttons. But the PCV does not change timming below 2500 rpm's https://www.youtube.com/watch?v=t3_RjEdk5ZI |
| Arkainzeye - 2016-06-17 1:32 PM So far my timing wheel set to +2 with riding 2 up and bike fully loaded with gear did not ping when u rode down to helen Ga and back .. it was perfect ! But at +4 it pinged with just me.. when the Temps got over 80f I had mine at +4 and with 91 octane. When temps got over 95 degrees I would get pinging. I dropped mine down to +3 and run 89 octane now and have never had pinging |
Posts: 3773 Pittsburgh, PA | I might try 3 then .. |
| katman
did you get cams or not
| olekneedragger - 2016-06-16 4:11 PM
How are you liking the suspension upgrades? Have you been in the mountains with that? |
Posts: 2118 Pitt Meadows, BC Canada | Anyone remember KevinX ??? He did my cams in 2008 in Bellingham Wa. as well as several more bikes while on a visit from Florida. The change was VERY noticeable and comfortable. Much more oomph from idle to top end. With Co-Pilot always aboard - the Vision easily pulls away from any HD and after 8 years, no problems. I see that Victory is now advertising S&S Cams for all 106 engines. |
Posts: 1632 Jasper, MO | donetracey - 2016-06-23 3:56 PM
Sure do. And Rylan. Rylan did mine way back when. I got about a 30% increase in horsepower--while running the stock exhaust no less.
In the Victory ads for the S&S cams, they claim a 20% increase in power, and you HAVE to buy the exhaust upgrade, and you have to have it all installed by a dealer and have them reflash your ECU. $$$$$$$$$$$$$$spendy.
I still run the stock exhaust with Lloydz cams and VFCIII and can run away from Harleys AND Goldwings. The S&S setup won't do that if it only gets you a 20% increase as they advertise. A 20% increase might let you show up some Harleys, but it won't let you outrun the Goldwings. You might almost keep up.
Lloydz stuff is a far better deal. And, he has been doing Victory performance for nearly as long as Victory has been around.
Ronnie |
Posts: 92 Moncks Corner, SC United States | I agree. I have Lloydz everything except exhaust, and I am happy with my 112 HP/115 TQ. When I started upgrading my Vision, I wasn't after squeezing every last drop out of the engine. Based on what I read in this forum and talking to friends, I chose what I felt would give me a significant increase in performance without breaking the bank. |
Posts: 196 Asheville, NC | I agree with Jimbo62. Not that my opinion matters. I don't wish to break the bank but I like what I see from Lloydz and they for my budget and my wish list.
Edited by j.wales 2016-06-24 5:32 AM
Posts: 3773 Pittsburgh, PA | i was wondering, who installed cams themselves ? if so what tools was needed.. |
| you need to take the bolts out of the frame in the rear behind the back cylinder. You have to lift it a inch or two so you can get at the front rocker box.
Then you need shop manual and basic hand tools and torque wrench |
Posts: 92 Moncks Corner, SC United States | When I did mine with the help of some friends, we could not get the fwd cam carrier out. Not enough clearance even with the frame bolts out and lifted. We had to disassemble it in place. Have a strong magnet handy as you may need to use it to remove the retainer pins in order to get the cam out. Not really a big deal. |
Posts: 3773 Pittsburgh, PA | I just ordered a set of these, then I will install them when I have enough time .
http://www.dynoguysmn.com/cams/rjlffgwsfnq05hv0o35l41h7s3ik69 |
Posts: 1632 Jasper, MO | Arkainzeye - 2016-07-28 12:11 PM
http://www.dynoguysmn.com/cams/rjlffgwsfnq05hv0o35l41h7s3ik69[/QUOT...
I'm curious why you chose those over the Lloydz cams. They produce no more torque, and less horsepower than Lloydz cams.
Posts: 3773 Pittsburgh, PA | Quieter for one.. and it's not about more torque it was about when the torque begins. Nothing night and day .. and besides the fact they were cheaper with no shipping costs on top of it.. and to be honest . It's quirk of mine, I rarely like to do what the masses do .. probably why I have vision living in HD country... like 6+ years ago everyone was like if you need a fuel controller you should only go with VFC, I said nah.. I'll go pc5..just cause I wanted to have more control .. it didn't give me more power.. I just rarely follow the crowd... im a pain in my own ass. !! Lol |
Posts: 1632 Jasper, MO | Arkainzeye - 2016-07-28 3:54 PM
Lol! I totally understand. I go my own way too. Been on Victory motorcycles for 16 years now.
I also buck the trend of putting loud pipes on my touring bike. I just get a kick out of having the fastest touring bike in the group I ride with (which includes some 1800 Goldwings as well as a bunch of Harleys) that looks and sounds 100% stock. It's a stealth bomber
Ronnie |
