Posts: 102 Parkersburg WV | Hi, I have an 09 Vision and added the sequential blinker kit a few years back. I thought I had a couple of bad bulbs but after taking it apart that's not the case.
On the right side everything functions correctly. On the left.....the bottom works fine but the middle and top bulbs only work as tail lights, no brake or turn signal.
Has anybody had this problem or know how to fix it ?
Thanks, Bob Scott
Posts: 366 Albuquerque, NM | You might want to contact Gary Lighton if you bought his sequential setup.
http://www.vision-mod.com/Contact.html |
Posts: 324 New Orleans, La, | I had a problem similar to what you are having. I sent them back to Gary and he found nothing wrong with them. Before they got back I changed the battery and upon reinstall it worked fine ever since, but I noticed if that if anything in the charging system is failing ie stator, rectifier/regulator, or battery they don't function properly. IJS you might want to go through your charging system first. |
