| I have a 2013 VV. Sadly, I had an accident and am in the process of replacing all of the front fairing pieces.
I need to find 2 of the wiring harness connectors (male) that plug into the turn signals (same connector is probably used many more places on the wiring harness). I have the female connectors that hold the turn signal bulbs.
Anybody know where I could buy the wiring turn signal harness connectors for a 2013 Vision?
If not, there are a few 08 main wiring harnesses on eBay. Anybody know if the 08 used the same connectors?
My last option is to solder wires to the leads in the female connector but I'd rather use the original connector from the wiring harness.
Comments/suggestions?
Thx, |
| maybe here not sure if 13 is the same as 08 or ebay
http://pinwallcycle.com/advanced_search_result.php?osCsid=k3bgk8a88... |
| I have both front turn signals and a rear harness. The rear connectors are the same as the front. |
Posts: 3773 Pittsburgh, PA | Are you referring to this item here ?
http://www.amazon.com/acdelco-pt2782-original-equipment-multi-purpo... |
| Awesome! Sure looks like that's the right one. I'll order it and find out.
Thanks again,
Mike
Posts: 3773 Pittsburgh, PA | From what i understood.. that part along with the part that holds the bulbs are GM parts.. btw. your welcome. |
