Posts: 277 Apopka, FL | I have a low beam out... Unfortunately, I had both bulbs replaced just this last May, I have read through all 5 pages of "Have you replaced your Vision headlamps".
My question is, I know the bulbs are H4, but what brand are the whitest and brightest and longest? Anyone have and words of wisdom? Someone suggested these, yea? Nay? http://www.amazon.com/PIAA-10707-Night-Tech-Upgrade/dp/B00544ZDDQ/r...
BTW, I am willing to pay my dealer to replace them!!! I have to work with my hands every day and it's not worth it to get them all sore and cut up. |
Posts: 3773 Pittsburgh, PA | I wonder if they touched the glass on your bulbs.. i see no reason why they are already burned out... if you have a issues with bulbs and their life then you need to focus on bulbs rated as a ( LL ) long life.
Edited by Arkainzeye 2015-10-18 7:26 AM
Posts: 482 Beer Collins, Colorado (there is no fort) | DD, I was probably the one that recommended the PIAA bulbs. They're hard to beat for brightness (I've had an Extreme White bulb in my '99 for years) & had the Night Tech bulbs in my vision until the low beam burned out in a little over a year/10,000 miles. I don't know if the frame mounted fairing on the Vision imparts more shock/vibration that shortens bulb life? My hands are important to me too & I wanted to put something in I wouldn't have to mess with for a long time-installed dual 55W 5000K hi/low HID lights 3years/30,000+ miles ago and they continue to light up the road better than anything I've ever had on a bike (5,000 lumens per bulb!). With no filament to break these should keep me out of the bulb replacement business for a long time. Best under a $100 upgrade I've done on the Vision.
http://www.ddmtuning.com/Products/HIDBIKESINGLEHILO |
Posts: 1632 Jasper, MO | If you are going to stay with the H4 bulbs, don't get anything other than the H4 of the LL (Long Life) heavy duty variety. They have heavier duty vibration resistant construction that regular duty H4 bulbs don't have. They are commonly used in the trucking industry. Regular H4 won't last a month in a truck, but the LL variety lasts for a long time.
The expensive bulbs from your dealer are the OEM LL variety. You can get them cheaper elsewhere.
Ronnie |
Posts: 341 West Salem, WI United States | ByteN2it - 2015-10-18 7:53 AM DD, I was probably the one that recommended the PIAA bulbs. They're hard to beat for brightness (I've had an Extreme White bulb in my '99 for years) & had the Night Tech bulbs in my vision until the low beam burned out in a little over a year/10,000 miles. I don't know if the frame mounted fairing on the Vision imparts more shock/vibration that shortens bulb life? My hands are important to me too & I wanted to put something in I wouldn't have to mess with for a long time-installed dual 55W 5000K hi/low HID lights 3years/30,000+ miles ago and they continue to light up the road better than anything I've ever had on a bike (5,000 lumens per bulb!). With no filament to break these should keep me out of the bulb replacement business for a long time. Best under a $100 upgrade I've done on the Vision. http://www.ddmtuning.com/Products/HIDBIKESINGLEHILO Just to confirm, the H4 Hi/Lo is the kit we need for the Vision? You installed 3 years ago, no issues with heat using the 55W bulbs? |
| I was leaning toward a set of those $!00 LED lights that are crazy bright until I read you post about these HID lights. From what I've read, unless there's a lens specifically made for an HID, the beam isn't what it "could" be whatever that means. Same with a set of LED's I think but I considering how poor the beam or spread of light is with the stock lights....personally I think they suck especially on HI....almost anything would be an improvement.
My question for you is how is the light pattern with your HID's? The stock Hi beams have dark areas and shadows all over the road and if the HID work with the stock lens I might try them. I was also wondering if you had a shop install them for you. Judging by the pics of the HID's they don't look like a simple plug and play.
Edited by beemerdad2@yahoo.com 2015-10-20 7:35 PM
Posts: 482 Beer Collins, Colorado (there is no fort) | No issues-I have noticed a slight color change between the two bulbs. The light pattern has a very distinct horizontal cut off line that can be adjusted the same as with any bulb-no issues with oncoming traffic flashing me. I did the install & everything does simply plug in-the trick is getting all the wire sorted & secured. I posted photos of the install and lighting up the road. I have heard some say the ballasts create radio interference but I haven't noticed as the radio reception was never any good to begin with. Best lights I've ever had on any motorcycle.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=12419&po...
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=11259&po...
Edited by ByteN2it 2015-10-20 9:35 PM
Posts: 8144 New Bohemia, VA | I've got both bulbs intact for about 3 years now, or more. One is a Philips, bright one, and I had a spell of those blowing every few months. I picked up some ATV long life for about $5 each, marked down at Wal-Mart. I replaced the one that was blown, again, that was about 3 years ago, and both are still going strong. I've almost forgot how to change the bulb. |
Posts: 37 Dayton, OH | I went with DDM HIDs; the 55W 6000K kit. Extremely bright; can see light reflecting off of signs in the bright sun light. 2nd season without any issues. Very happy with setup. |
| I found these don't see why they wouldn't work
http://www.dragspecialties.com/products/?productId=332715 |
Posts: 423 northwest florida | LED or HID. only way to go. Less draw on the electrical system also which means MORE FARKLES!!!! |
Posts: 3773 Pittsburgh, PA | http://www.consumerreports.org/cro/magazine/2013/01/halogen-headlig...
Posts: 3773 Pittsburgh, PA | On my vision I replaced my own bulbs with philips crystal vision . I didn't use H4 I used 9005. (Google it ) I did this to match the color of my HID light and it worked. I think they were like $39 for a pack of 2 |
Posts: 115 Katy, TX United States | johnnyvision - 2015-10-24 6:02 PM
Has anybody tried these? |
