Posts: 576 , IA | under warranty went for a ride yesterday in the a.m.and had my windshield up, have not rode much with it up but it was cool since buying my bike, first time in cool weather and my god the distortion is so bad that when doing the curves on hwy 20 in Ill. it scared the s*** out of me just wondering if vic will replace with a proper windshield for no cost  |
Posts: 293 Arkansas | My dealer replaced mine, but it took rejecting 9 of them
before getting one that was good enough. Hopefully yours was
One of the early ones and a replacemet will be easy.
Victory was supposed to have scolded the supplier and should have
fairly good quality now; I did notice some of the same
on an '09 though but not as bad as before
Edited by jama 2008-10-12 9:36 AM
| Had mine replaced under warranty but due to cracks at each of the mount screw holes. Had the 2" taller put on instead of stock. |
Jacksonville Florida | Bought a Cee Bailey green tint shield. They will cut it the lenght you want and there isn't any distortion. The Cee Bailey sheild is 8MM thick. I think the Vision shield is about 6MM thick. Mudge turned me on to Cee Bailey. Best accessory that I have added so far. |
| I had my original replaced under warranty because it was crooked....replacement is fine. |
| mine is being replaced under warranty. i think they got a good one the first time out. just need time ot get the bike in. |
Posts: 6 N. Attleboro, MA | Had mine replaced and although there is still a slight hint of distortion, it is definitely ok. Checked out other windshields before they changed it to avoid the same problem...or one that was worse. Dealer was more than helpful and it was warranty. Amazing what a difference it makes. |
