| just wondering what to do belt might be alittle loose . but when you ride at 60 degree in the am to 100degree in thepm . belt is way tightwhen warm but chirps when cold and wet .some one mentioned some parrifin wax.seen five visions in the blackhills last weekend wow thatsawesome. |
Posts: 154 Danbury, Connecticut | Gary, try this post by Pollolittle. The belt is rubbing the side of the pulley. Get it towards the center and the noise will stop. Not sure if this site automatically creates the link, if not, you'll have to cut and paste. http://www.vision-riders.com/bb/forums/thread-view.asp?tid=794&post... |
| you have to adjust the belt when its over night cold.
Not warm or hot cause the settings change then |
| Just put some Oil of O'lay soap on it every 3k miles.  |
| if you don't do it your tire will wear funny. Your brake pads will wear uneven. You can shorten the life of the belt |
