Posts: 44 Houston, TX United States | Found this today, has anybody had this issue, looks like the Heated Grip power wire.
 (Grip.jpg)
| yup looks bad ebay might be a good place to find new grips |
Posts: 44 Houston, TX United States | Thank You Johnnyvision !!! |
Posts: 1632 Jasper, MO | If it were mine, I would probably splice it back together.
Ronnie |
Posts: 1229 Rancho Cucamonga, CA | No real way to splice it back. The movement of the throttle will keep breaking it. I replaced mine with heated Avon grips. Cheaper with a beefier cable. Only bad thing is you have to use their controller instead of the hi/low switch already in place. |
Posts: 1632 Jasper, MO | I understand about the throttle movement. I would probably try installing a beefier wire to the assembly and doing the spice upstream, away from the moving parts. Might not work, but I'm cheap and would have to try.
Ronnie |
| doesn't look like there is any wires sticking out to reconnect.
guys this a good time to look at yours and see that when you twist the throttle the wire moves freely |
Posts: 44 Houston, TX United States | Johnnyvision, your correct there are no wires sticking out it broke off even with the Grip. |
