Posts: 64 Northern RI | Finally after 5 weeks got a new radio and CB. They are new because the others didn't work right. Well I get everything put back together last night and meet a couple of friends to see how everything is working. Now I have another problem. When they talk to me, it sounds great, volume perfect, get the RX on the display, I'm thinking great. Then I transmit and I can hear myself through the helmet speakers. Their speakers cut out as if they are receiving me, but there is no sound. TX shows up on my display and RX shows up on their display. One of my buddies called it a dead carrier. I have the J&M headphones with the HO mike. I know they work because my buddy plugged it into his ultra and it worked fine. Am I missing something simple? I've also tried all the different settings etc. AVC, CBvolume control, ICOM volume control, VOX, Local and Distant settings and so on. Any suggestions would be a great help. Thanks to everyone in advance.  |
Posts: 3006 San Antonio, TX | I think that Harley and Victory use the same plugs with different pin outs. So....A Harley headset will not work on a Vision.
Maybe someone can confirm this.
Posts: 293 Arkansas | If you are using a Harley lower cord, it won't work. You can get a j&m cord for the vision- my guess is that will fix it for you. If you already have the proper lower cord, then I'm not sure. |
Posts: 447 Cleveland, GA | radioteacher - 2008-10-11 12:53 AM I think that Harley and Victory use the same plugs with different pin outs. So....A Harley headset will not work on a Vision. Maybe someone can confirm this. I can confirm it. When I ordered my lower cord from J&M in the early days of Visionness, I was told that J&M's Harley cord would work. It didn't. I spoke to the president of J&M, who told me the pinouts were different and that they had developed a cord to fit the Vision. I bought two and they have worked great. No problems with reception or transmission. You also might want to check with J&M about the High Output mike. The company president told me something about one of the mikes they sold wouldn't work well (or at all - I misremember, since it was nearly a year ago). Give J&M a call about it.
Edited by Lone Ranger 2008-10-10 9:19 PM
Posts: 1632 Jasper, MO | The pinouts are different. All you need is the proper lower cord from J&M. The HO microphones work TOO good on the Vision. They will pick up all the ambient noise and make the CB transmission hard to understand at any speeds over 60-65 mph, especially if you're riding double, since both mikes are active. HO mikes are not needed on the Vision. That's what I have (I figured I would get the best for my Vision) and I'm experimenting with ways to mute the mike. On the upside, the headset speaker volume is VERY good with the J&M's. I've been meaning to call J&M and see if they have a less sensitive microphone that I can replace mine with. The J&M's are modular, so it would be easy to substitute another mike. I've always found J&M to be very customer oriented, but I've not had time to call them during business hours.
Ronnie |
Posts: 293 Arkansas | I was told b J&M that all you have to do to decrease the output on the HO mike is block a few of the holes in the mic face plate. The reason this works is due to the fact that there is no difference in the mic, other than that. You could just put a little drop of nail polish or similar substance in a few holes until you get the response you desire. Or, find a non-HO mike and count the holes and duplicate that. Of course you can call them to confirm this, if you want. |
Posts: 64 Northern RI | I should have given a little more info. I do have the J&M patch cord (2 of them) for the Vision. We were testing that cord on his bike with his headset. Just to rule out the cord. |
