HID/Headlamp Adjustment
southjerseyrider
Posted 2015-07-03 2:30 PM (#173185)
Subject: HID/Headlamp Adjustment
Vineland, NJ United States
If I adjust my Low Beam down, will the HID also be lowered?  When I use my HID at night, I keep getting flashed by oncoming traffice.  So I was going to try lowering it a little.
Posted 2015-07-03 2:48 PM (#173186 - in reply to #173185)
Subject: Re: HID/Headlamp Adjustment
i used to get flashed all the time.. i never adjusted mine.. and for some reason the flashing hasnt happened in a long time.. it could be that its out of adjustment OR. it could be they are not used to bike that bright and up that high.. if you think about it our head light is way higher than a car.. like right in the path of a rear view mirror.., you can probably google the proper procedure on how to adjust a motorcycle headlight instead of just keep turning to lower.. especially if its not out of adjustment..
Posted 2015-07-03 5:16 PM (#173188 - in reply to #173185)
owners book will tell you how to adjust it. When you get it right Sit on it to make sure. Your weight will raise the light
