| I have a 2010 Victory Vision Tour motorcycle with just under 30,000 miles accumulated. At the inside and the outside edges of the belt is a bit of fraying with thread starting to show. Have any of you had to replace the drive belt and if so at what mileage? Did you also replace the pulleys? |
Posts: 804 Perry Hall, MD | Suggest you search the site for previous posts on the topic. Think you'll find 30K is too early for most, and pulley replacement isn't discussed much. I'm at 60K and not planning to replace it any time soon. |
Posts: 1308 Sand Rock, AL United States | 112,000 miles still on original belt  |
| talk to dealer I'm think bad pulley. Try to get dealer to call Vic and get it covered |
Posts: 3773 Pittsburgh, PA | What is the recommend service (replacement ) interval for the belt? |
Posts: 196 Asheville, NC | I thought the book listed the service interval at 30K. 112K, wow. |
Posts: 1632 Jasper, MO | j.wales - 2015-06-30 4:26 AM
It does, along with a host of other things, such as clutch fluid, brake fluid, spark plugs, air filter, and fork oil.
Might be a bit conservative for some of those things.
Ronnie |
Posts: 416 Prairie City, IA United States | 80K on my drive belt. I just keep an eye on it and when I see wear that requires a change, then I will have it changed out. These belt have been used in the Grain handling and sand and gravel industries for years to run drives. They log thousands of hours without any issues. They are tough. |
Posts: 8144 New Bohemia, VA | I trust the belts also, the difference though is ours has a greater variable of stress and exposure to harsher conditions. I think the greater risk will come from dry rot, starting around the 6 or 7th year of use. At that point you've gotten plenty of use out of, it's time to have some peace of mind. |
| Victory is out of there mind telling us to replace the belt at 30 thousand. $300 for a belt and over two hours labor when there is nothing wrong with it.
To think Harley runs the same belt from the same manufacturer and 1/2" narrower and they say to inspect at 80 thousand
Are we fools for following Victory |
Posts: 1365 Central Maryland | johnnyvision - 2015-06-30 6:21 PM
Victory is out of there mind telling us to replace the belt at 30 thousand. $300 for a belt and over two hours labor when there is nothing wrong with it. To think Harley runs the same belt from the same manufacturer and 1/2" narrower and they say to inspect at 80 thousand Are we fools for following Victory Only if you enjoy a raping (of the wallet). |
