Posts: 1290 Ruskin, Fl | Has anyone had a section of theirs go out? About the last third is out. If I push on it right where is stops working it will briefly come on. Obviously a broken connection internally. Is there a fix or am I out $100? |
Posts: 251 Mechanicsville, VA United States | These are the ones I have and they good great day or night.
I bought 2 strings and cut them so I have left turn/right turn and running lights and brakes lights.
https://www.superbrightleds.com/moreinfo/side-emitting/waterproof-le...
and didn't spend no where near the amount you spent. You might want to give them a try.
As far as fixing your I have no idea if you can cut them or not but they are usually marked where to cut so you may be able to shorten them if the lights that are out are on the ends. |
Posts: 92 Eau Claire WIS. 09 vision | i have the 99 also the day i installed it three bulbs went out. took a pic sent to the company. they sent me brand new one with in a week. |
Posts: 1290 Ruskin, Fl | Wow. Much cheaper than Stingerz. Thanks.
And as far as contacting the company, they been on the bike 2 years. I'll cut the dead section off and mount them under the tanks or something.
Thanks. |
