| Anyone know if there is a plain throttle tube that is available for the Vision?? I'm looking to replace my grips and need to replace the throttle tube since it's got the stock heated grip which looks to be non - removable.. Or is the non heated RH grip removable from the throttle tube? If so I see I can buy a RH grip from Polaris and that would do the trick...
Edited by Aprider 2015-06-04 11:17 AM
| if you buy a quality grip it will come with a throttle tube. If it doesn't don't buy it | |
