ABS Warning light on
steelhorserider
Posted 2015-04-18 4:43 PM (#171948)
Subject: ABS Warning light on
Breaux Bridge, LA
This is my first post so I hope it goes well. I got a 2011 about a month ago. The old owner had the dealership change the ABS sensor since the light stayed on. A week of riding and the warning light came back on. Dealership is 2 hours away or I would take it back.
My question: Is there any harm to the bike is I don't fix what ever is causeing the warning light?
Posted 2015-04-18 7:27 PM (#171952 - in reply to #171948)
Subject: Re: ABS Warning light on
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=9779
V-rodder
Posted 2015-04-19 1:00 PM (#171971 - in reply to #171948)
Only issue is you wont have abs brakes. Just regular brakes.
Posted 2015-04-19 1:54 PM (#171972 - in reply to #171948)
if i remember correctly.. and dont qoute me on this.. Some people had an issue with the ABS due to clearances between the sensor and the ring...?
Pops
Posted 2015-04-19 4:01 PM (#171976 - in reply to #171948)
Georgia On My Mind.... United States
Just some random thoughts from my BMW ABS experience.
The ABS wheel rings are sometimes damaged with a tire change. If the brake fluid level is just a little low, on a BMW the ABS light will flash or come-on. Especially the rear master cylinder.
steelhorserider
Posted 2015-04-20 5:16 PM (#171995 - in reply to #171976)
Breaux Bridge, LA
Thanks for the replies. I've made it this long with no ABS I'm sure I'll make it till the end without. LOL
Turk
Posted 2015-04-21 7:49 AM (#172005 - in reply to #171948)
I had a bad sensor on mine a few years ago, and it caused the ABS light to stay on. But, more importantly, it caused occasional braking issues, where no matter how much pressure I applied to the front and rear brake levers, it refused to transmit to the calipers! Very scary when you can't stop the bike! I would get it looked at ASAP!
Posted 2015-04-21 9:41 AM (#172010 - in reply to #172005)
Turk - 2015-04-21 7:49 AM
I have had that happen twice over the years on semi-trucks. No matter how hard I pushed the brake pedal, I had no brakes. The manufacturer says that is impossible and that the system is supposed to revert to manual braking whenever there is a sensor problem. Reality is that the brakes did not respond at all, even though there was substantial air pressure and pedal pressure. Bad sensor = no brakes.
No ABS for me on my bikes, thank you.
steelhorserider
Posted 2015-04-25 8:12 PM (#172107 - in reply to #172005)
Breaux Bridge, LA
Thanks for that.
