Posts: 24 Chicago | I recently aquired a set of the Polaris (PIAA) and attempted to install. Everything went great until time to plug in the lights, I have removed the facia on my bike and all body work searching for a plug that has a yellow/red wire and a black wire and I assure you none exist. there is a plug that has a yellow/red wire a pink wire and a black wire but it does not plug into the fog light, when the motorcycle is started the tellow/red wire becomes "HOT" (power passes thru) and will power the lights and the black remains a ground. The pink wire does nothing. Am I missing something. I have a 2013 Vision and the fog lamps are Polaris #2875746. Any help is appreciated. |
Posts: 29 Tumbler Ridge, BC Canada | Hi dose your bike have the HID headlight. My PIAA fog lights turn on when I turn on my HID. I can?t remember where I found the plug I think it was under the radio cover. I am going to be working on my bike in the next day or two if you haven?t found it by then I will look to see where it is. |
Posts: 24 Chicago | Trshooter. I do not have the hid in my vision. |
Posts: 804 Perry Hall, MD | Look for wire tucked up behind the right turn signal. |
| look at the HID ballast there is a extra wire there |
Posts: 24 Chicago | I have looked everywhere and still can not find the plug. Only plug I found is the one with 3 wires (black,pink &yellow/red) and it was located directly behind the right side turn signal. |
Posts: 17 Virginia Beach, VA United States | I also ordered the kit when it was sale, but it would not fit my 13 Vision. The kit only fits 08-10, so you need to contact Ma Vic's part supplier. They will send you a new instructions and an additional wire harness that is to be used on Visions 11 and up. My lights are installed and I am waiting on the harness. The wire you found on your 13 Vision is correct. You will also notice that you did not need to replace a relay. If you want, PM me and I will send you the new instructions. However, I am leaving tomorrow (Friday) and I will be out of town till Sunday night. |
Posts: 17 Virginia Beach, VA United States | PM sent
Edited by Bchviking 2015-04-16 9:27 AM
