| The belt on my 2011 Vision caught a rock and needs replacing. I was a bit shocked at the OEM belt price. Is that the best belt or are there high quality aftermarket ones that are not so stupidly priced?
Thanks
Jim |
| Dealer Its the only place you can get a belt from. No aftermarket belts around |
Posts: 1365 Central Maryland | Check the classifieds here. This one may still be available:
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=19047&po...
| Thanks for the info. Found one on eBay last night for $132 with only a few thousand miles of use. I just can't believe that with all the companies making HD belts, that none of them make any for Vic. |
Posts: 1365 Central Maryland | I'd think that you could take your belt into a HD dealership and let them see if they can size it up; with one of theirs? Maybe? |
| I was surprised last fall while I was waiting to get a new rear tire installed on my bike. Just for giggles, I asked the parts counter guy about the price of the drive belt for a Yamaha Roadliner and I couldn't believe how much more expensive it was compared to the Vision belt.
I've always tried finding alternative parts/prices for my bikes and I'll keep looking but I sure wasn't expecting the Vic belt to be cheaper. |
| Y-Ridder
when you put the used belt on make sure you can read the word victory facing outward.
Used belts are like radial tires they wear a certain way. Doing it wrong will shorten the life of the belt |
| Thanks for the heads up. Having the dealer install it.
Ride safe
Jim |
Posts: 3773 Pittsburgh, PA | doubt a HD dealer would be able tp match one up.. there are very specifics to that belt... 28mm 154 Tooth... im not sure how many HD belts rae 154T ... |
| Highest teeth count I can find for HD is a V-rod at 150T. Most are in the 130's. |
