 Watauga, TX United States
 | Is there a shock with a higher preload than the stock shock.  two up @ 70lbs shock preassure the ride is a bit back heavy.(hush) meaning the rear end hangs a bit lower. (don't)  I guess what i am asking is there  a stiffer shock i can upgrade to to lessen rear end sag.  |
 | penske not cheap |
 Perry Hall, MD
 | $$$$  and not sure that it is what you are looking for, but check it out: http://www.platinumairsuspension.com/productguideVictoryBF.html |
 | Thanks guys, this is exactly what i was looking for. Some control over the ride height.  Yes a bit spendy will be saving my pennies |
 | you;ll hate the ride it will give you |
