  Posts: 8144 New Bohemia, VA | The last time I replaced it I dremeled out. This time I had planned on using a blind hole puller, but I can't find one that is 2 1/2 inches like the race is. So now I'm stuck. I used heat on it but didn't want to go to far with that, nothing so far. Any advise, tool, or something is appreciated. Don't say take it to the dealer, it ain't happening, I'll dremel it again. Thank you.  |
  | go to a rental shop and see if they can hook you up |
  Posts: 8144 New Bohemia, VA | I tried the auto parts stores today and when i asked for a blind hole puller, they all said,  "Huh?" I'll try some real places Monday.   Thanks! ! |
  Posts: 482 Beer Collins, Colorado        (there is no fort) | Harbor freight has a decent blind bearing puller & bearing separators too. |
  Posts: 8144 New Bohemia, VA | Not large enough, only 1 7/8 or some like that, need around 2 1/2. |
  Posts: 482 Beer Collins, Colorado        (there is no fort) | I just peeked in the manual and it says to drive the lower bearing race out evenly using a long flat punch through the access slot. |
  Posts: 8144 New Bohemia, VA | I don't have any access slots. I don't know what to do.  |
  Posts: 2027 Brighton, TN | If you have a welder.  Weld a large washer to the race.  Then run some all thread through and put a nut or two on the other side.  If you get a long enough piece you can stick it out the top of the neck and tighten the nut up to the washer.  Then hammer from the top or if you have an impact driver just drive it out.  Or if not replacing top bearing.  Use the all thread as a slide hammer.  I put nuts and a large washer at the very end and grabbed a hold of the all thread and started banging away.  It will take some effort that way but it will come out.  If you could rig up a weight to run up the all thread and slam into the end with other washer and nut it would probably be a lot easier.
  Posts: 2027 Brighton, TN | I had no access hole. |
  Posts: 3773 Pittsburgh, PA | i dont know if this would be of any use to you or not?   but i wanted to share it either way .  https://www.youtube.com/watch?v=h97vUOJI9gk |
  Posts: 8144 New Bohemia, VA | I don't have a welder, Brian, wish I did.  I'll probably do two notches in the cast, it shouldn't mess with the integrity of the seat, and drive it out.  Right now I'm down, and not much of a window to work in.
thanks for sharing, Chris, I'm going to try that, but I don't think the seat is the same for the vision as it is in the video. |
  Posts: 341 West Salem, WI United States | Check with KevinX, he would know the what and how, he's active on the VOG facebook page. |
  | access hole is the steering stem hole.
ask for a break drum race puller. same thing but they will understand you now.
Or go to aftermarket bike shop and ask if you can rent theries |
  Posts: 8144 New Bohemia, VA | Book says notch. Can you post a picture of the bearing puller you are speaking of?  This is my second go round and it's got me down to do the welding or dremel.  This time I'll drill the holes to drive it out next time.  This is a pure blind recess, no place to grip or drive, zilch. |
  Posts: 482 Beer Collins, Colorado        (there is no fort) | I had mine apart a month ago and just cleaned/re-packed-everything looked good and feels solid (48,000 miles). I have new bearings but chose not to replace this time around. One thing I was looking at is drilling & tapping a grease zerk so you could lube the lower bearings with a mini grease gun rather than tearing everything apart. Part of this mod would involve carving a passageway from the zerk to the inner bearing. If you do use a Dremel cutting out the race one could position the cutting wheel so that any over cut could be used as a passageway for the grease to get to the inner rollers. Just something to consider while your working on it-I added grease zerks on my old Vulcan at the steering head & swing arm bushings-they can go a long time if you can keep 'em lubed up. |
  Posts: 8144 New Bohemia, VA | For those who are following, I'm still hacking the race out. Sometimes I think I should give up wrenching for my own good. I had tapped the new bearing on the shaft and had it down to a 1/16 of an inch from seating, so I thought. I finally took it to the craft shop and pressed, and it still had the gap. In the process I messed up the cage on the new bearing and rendered it unserviceable. I brought it home and remove the hosed bearing. Guess what? That 1/16th of inch gap is the exposed edge of the seat.....I had it on here at the house and didn't even realize it. Well, off to ebay to get another bearing. |
  | if your race is smooth you don't need to remove it.
If it looks like one of these then yes
   (brgChatter1195181899.jpg)
   (countershaftbearingrace.jpg)
  Posts: 8144 New Bohemia, VA | It's shot, no doubt.  Especially now, it's almost cut through.  But it was waste... |
  Posts: 8144 New Bohemia, VA | Here's some pics
   (image.jpg)
   (imagea.jpg)
  Posts: 2027 Brighton, TN | I'm surprised at you and the tenacity with which you persevere.  Congrats on getting it out.  I'll have to see if the blind bearing puller I bought is big enough or do I need to hit the inner Web for the puller. |
  Posts: 8144 New Bohemia, VA | I bought my blind puller at Harbor Fright about a year ago.  The largest is 1 3/8 or something like that.  We need about 2 1/2 and I just don't where they exist.  I tried to see if Polaris has something, but they are elusive in this area.  The book says there are "notches" to drive it out, yeah, right, nooooo notches, nada, none.  I figure I could drill a hole above, but that would just compound the moisture problem, so no.  I thought about drilling a hole to the bearing for a zerk, but I don't see how to place that to lube the bearing.  So, when I get the new one, I'll shove it together and get back on the road.  I'm having major withdrawals... |
  Posts: 8144 New Bohemia, VA | Lower race installed, spanner wrench dressed up.
   (image.jpg)
   (image.jpg)
  Posts: 8144 New Bohemia, VA | Lower bear installed. Time to pack with grease.
   (image.jpg)
