2013 Vision Climate Temp Gage
13Hambone
Posted 2015-04-02 12:07 PM (#171609)
Subject: 2013 Vision Climate Temp Gage
The climate temperature gage on the dash is only showing --? Anybody else have this?
Posted 2015-04-02 5:20 PM (#171614 - in reply to #171609)
Subject: Re: 2013 Vision Climate Temp Gage
the pick up is behind the left hand mirror. Pull aluminum panel and with a flash light you can see the wire. Pull it out of the slot its in and then see what you get.
If you run wire down below fuel tank and zip tie it to over flow tube it will be 99% accurate. If the gauge is not broke
13Hambone
Posted 2015-04-06 11:14 AM (#171679 - in reply to #171609)
Thanks!
icemann
Posted 2015-04-07 9:26 PM (#171710 - in reply to #171609)
, OH
too funny. It took me two days to figure out what that wire went too. its behind the driver side mirror on a plastic dimple. The grey plug behind it in the photo is what its connected to. pink, blue wires.
Edited by icemann 2015-04-07 9:30 PM
icemann
Posted 2015-04-07 9:26 PM (#171711 - in reply to #171710)
, OH
jd
(20150327_165022 (Medium).jpg)
Attachments 20150327_165022 (Medium).jpg (34KB - 0 downloads)
