Posts: 167 , OH | Well this started off as more of a repair. Then turned into a why not might as well.
Stock heated seat in driver location failed to heat.
Ended up replacing the drivers seat heater with one from sergeant. Took some modifying to get the factory seat switches to assist. Shaved the foam down and made it more custom to my shape and ride position.
Added back massager and separate independent heat to the driver back rest. Much needed when you have back pain and use new vocabulary words like ointment.
Added massager to the passenger seat "sweet spot". Connected trigger wire to ignition coil circuit. Faster you turn the throttle the more it vibrates. Passenger heater still functions as normal. Hate that now Victory has passenger back rest on sale. Arrrggg..
Recovered seat's and back of trunk seat pads. I'm not the best sewer. Heated it to shrink to fit.
All controlled by remote control key fob. 8 channel fob. Controls LED's, custom ghost lights, seat massager, passenger seat "massager", Aux charger in radio console base, garage door opener.
Finally named the bike too.
 (seat3.jpg)
 (seat heater.jpg)
 (massager.jpg)
 (seatback1.jpg)
 (seat5.jpg)
 (seat1.jpg)
 (seat2.jpg)
seat heater.jpg (39KB - 1 downloads)
Posts: 752 Broken Arrow, OK | If you don't already have one, Rylan at The Vic Shop sells T-Shirts with "Can't leave well enough alone" boldly on the back. I think they were designed around you!!!
Great job | |
Posts: 366 Albuquerque, NM | +1 | |
Posts: 167 , OH | Lol thanks. I figure if your going to tear it all the way down, fix it while you can
Posts: 691 Manchester, CT | awesome work | |
Posts: 167 , OH | My passenger says this is the best part
 (20150327_155351 (Small).jpg)
 (20150327_155344 (Small).jpg)
20150327_155351 (Small).jpg (50KB - 0 downloads)
20150327_155344 (Small).jpg (49KB - 0 downloads)
