| I found this and am woundering if I could wire this in and use as a on off switch. Hate using the key http://www.amazon.com/AGT-Waterproof-Wireless-Universal-2-Channel/dp/B0068D0OBI/ref=pd_sim_hi_2?ie=UTF8&refRID=1VJ76MDQPN3T39F45AXF |
| I'll try this again
http://www.amazon.com/AGT-Waterproof-Wireless-Universal-2-Channel/d... |
| In theory, yes you should be able to - in fact, if I understand the device correctly, you could theoretically use the "A" channel as ignition on, and the "B" either as an alarm activation or to trigger only the ACC circuit. However, I am a new owner, so someone here with more knowledge of the circuit would be better able to determine details necessary to make it work that I cannot say without a schematic. Some questions I immediately think of in determining how to make it work:
1. Does the remote latch its internal relay, toggling closed or open between presses of the button, or is it momentary? If momentary, you will have to have a latching relay system to keep the ignition circuit energized.
2. This also relates to a question of how the ignition circuit works - does it latch a relay as long as it is energized? If so, then you have to have a way to break the power to turn the ignition off. Once again, if the device does not toggle and latch internally, you will need another relay to break the circuit, possibly having to trigger it by use ot the second channel of the remote.
3. How many circuits are triggered at once by the ignition switch, and of those how many are direct and how many run from a triggered relay? How much total amperage is necessary for that circuit. If for no other reason you may need to have the remote trigger a relay rated for higher amps than the remote is rated for.
Clear as mud, right? As said, I am sure there is a way to make it work, and it is an interesting idea, but someone with more knowledge about the wiring of the bike would need to chime in. Of course, there is the observation of "Cool! A good reason to squeeze some more wiring and gizmos into a Vision!" |
| maybe this would be better. Just try to find a way so I don't have to put the key in the ing all the time
http://www.amazon.com/RM01-Channel-Wireless-Control-Off/dp/B000ZRXJ... |
Posts: 341 West Salem, WI United States | Victory and Digital Guard dog both make these. Although they are quite a bit more expensive than that, but guaranteed to work. |
Posts: 3773 Pittsburgh, PA | i was just wondering. if using this to bypass the keys on your bike. (not using steering lock i guess) would there be a constant be it low, drain on your battery to have this device in a "ready state" ? if so, how long could this be installed by not used before a battery might be to low to start the bike..
also i was wondering if there would be any type of fail safe.. example.. my buddies harley wouldn't allow him to start the bike before the alarm malfunctioned .. could this happen using this device? |
Posts: 3773 Pittsburgh, PA | disregard blabber above. i should learn not to try and reply to anything over a cellphone that freaking (auto-pisses me off) changes my wording... |
Posts: 167 , OH | You could consider a biometric scanner to start the bike. no key would be needed. $300.00. Pretty easy to do.
http://www.fistenterprises.com/
https://www.youtube.com/watch?v=6uGb0m7f5R0
http://www.12voltnews.com/wp-content/uploads/2013/02/scanner-with-f...
Edited by icemann 2015-04-03 6:24 PM
Posts: 167 , OH | then you can mount it to the bottom of the "V" below the power button on the radio like I did. The scanners are really small
Edited by icemann 2015-04-03 6:35 PM
 (dash.jpg)
 (scanner-with-finger1.jpg)
Posts: 804 Perry Hall, MD | Icemann, Just waiting for you to tell us about the hyperdrive you installed to go to light speed. Love the thinking outside the box! |
Posts: 167 , OH | oh the hyperdrive. Im too old to go fast. 2mph so everybody can see me. http://www.visitoakdaleca.com/wp-content/uploads/2013/11/bike-light...
| <p>guess I'm just going to run a tago switch under a tank panel. On/off is all I need. Can always pull the key out to lock it</p><p>I must say harley has the answer to this </p>
Edited by johnnyvision 2015-04-04 6:58 PM
