Posts: 4 Burlington, North Carollina USA | Howdy all! I have a 2011 Vision with all of the OEM communications equipment installed i.e. intercom, CB radio, am/fm, XM satellite. If possible, I'd like to be able to just have a rider/passenger microphone for use with the intercom and earbuds for listening to XM and CB radio. Any ideas or thoughts on how or where I could get such a system would be appreciated.
Thanks in advance! |
Posts: 466 Grand Cane, LA | Here's a thought. Get a J&M helmet headset and have someone replace the helmet speakers with a 3.5mm female jack and keep the speakers and put a male 3.5mm jack on that end that way you could use the earbuds and when you get tired of that you could put the speakers back in. I personally am using a Cardo G4 that I did the same thing with. You can get the 3.5mm jacks from Radio Shack and any competent electrician or audio person can put them on. |
| New sena smh-20 works with ear buds. Not familiar with your set up, but hope it helps |
Posts: 1632 Jasper, MO | BruceHarrisJr - 2014-10-21 8:07 PM
Thanks in advance!
Are you wanting to use earbuds instead of helmet speakers? A J&M helmet speaker setup would plug directly into your bike.
Edsets makes the earbud adapters for the 5 and 6 pin systems and has promised to release a 7 pin version. I do not see it on his website yet. You might call him http://www.edsets.com/product_details.php?item_id=161
Ronnie |
| you can also check out 'plugup' version... it does work. Only problem is it eventually 'breaks' because it's not rigid - got about 3 riding seasons out of mine before it died today... lol
I sent email to EDsets to see if he's making the 7 pin system...
link to plug it up: http://www.plugup.com/5_pin_6_pin_7_pin_audio_mic_stereo_earbud_ada... |
Posts: 2 Billings, MT United States | Be careful with ear buds, in some states it is illegal to use earbuds/headphones while operating a motor vehicle!!!!!!!! |
