08 sound upgrade continued
icemann
Posted
2014-10-13 11:08 PM (#167318)
Subject:
, OH
Part 1:
icemann - 2014-08-23 10:25 AM
How I tackled installing 6 1/2 inch speakers on a victory vision in the stock space. (as well as the rest)
This can easily be done on the bike.
Adding Rockford Fosgate T400 x4ad 400watt 4 ch amp, and 2 Rockford Fosgate T400 x2ad 400watt 2ch amps
(2) 6 1/2's for the front (Fosgates)
(2) 5 1/4's for the rear (Fosgates)
(2) 8" marine grade subs to the rear bags.
And a bunch of other's while it is nakid. over 1200 watts Clean
First. Size perspective stock to 6 1/2's.
Minor cuts needed on speaker itself to fit stock space.
THE STOCK LOCATION - LINE UP CUTS ON SPEAKER
TRIM 1/8" around the circle to make 5 1/4 to 6 1/2 cutting off to ALLOW ROOM FOR THE CONE TO MOVE
AMP ON LEFT GAS TANK AS USUAL. 2nd amp in left bag.
FUSE BLOCK FOR ACCESSORIES IN LEFT BAG XM MOUNT HOLE.? NICE ADD ON EASY REACH
WIRE LOOM EVERYTHING FRONT TO REAR neatness counts.
THE REARS. 5 1/4 stock location. plug n play. (new wires to amp)
I HOPE THIS HELPS SOMEONE.
ICE~
Modified the rear bag liner back wall by drilling holes for sound to exit. Made adaptor to hold speaker. Fosgate MGII 2 way subs.
Then sealed and carpeted the subs.
Then Wired in amps on each side.Wired in fans to move air and made a cover panel
Lastly sealed off the front speakers for sound leaks.
That's it for now.
Edited by icemann 2014-10-13 11:32 PM
(2014-10-11 17.10.30.jpg)
(photo (2).jpg)
(2014-10-11 16.21.25.jpg)
(2014-08-18 16.24.04.jpg)
(2014-10-11 16.22.46.jpg)
(20140811_131919.jpg)
(20140811_113737.jpg)
(20140811_133116.jpg)
(20140811_132910.jpg)
(20140811_132117.jpg)
(2014-08-22 17.23.18.jpg)
(76KB - 28 downloads)
(66KB - 12 downloads)
(59KB - 14 downloads)
(31KB - 11 downloads)
(55KB - 12 downloads)
(49KB - 12 downloads)
(65KB - 14 downloads)
(54KB - 12 downloads)
(39KB - 20 downloads)
(73KB - 12 downloads)
(43KB - 14 downloads)
