Posts: 341 West Salem, WI United States | Quick review, I will update after an upcoming trip with 6 guys using these headsets. SMH10 - Good headset - Easy to install, and you can get different types of mikes based on your helmet
- Connected quickly to any device I tried to connect; GPS, Android phone, BT transmitter etc
- Speakers sound good, not much bass since they are little speakers
- Talking to pillion and/or other riders is good and clear
- Range is about 1/4 to 1/2 mile line of sight.
- Group intercom, limited to 4 headsets
SMH20s - Great headset ! - Wow, what a difference in sound quality! Very impressed with the amount of bass from the upgraded speakers
- Conversation is even more clear than the 10 was
- Audio multitasking lets the music keep playing during an intercom session, it just lowers the volume for you
- Install was the same as the 10
- Microphone has been improved quite a bit, much less wind noise etc
- Added an "ambient" noise button, so when you are filling the gas tank etc and have your helmet on you can hear the conversations around you outside of your helmet !
- Double tap on your helmet near the device and it wakes up and asks you for a voice command
- Just say "hello sena" and she wakes up and asks for a command
- Range is supposed to be over a mile (2k) if only the 20s models are used, less if in a mixed environment
- Can connect to other brands of headsets
- Group intercom now expanded to 9 headsets!
So far, I really like the new version. We will be using them for the Sturgis trip, so 6 guys with 5 SMH20's and 1 SMH10. Should be a great test of how they work together (or not). |
