| I need a hazard switch for my 2008 Vision. The local dealer wants $53. inclucing tax. Anyone know where I can order a cheaper one on line?
Posts: 8144 New Bohemia, VA | what? are you sure it's just a switch? It's a three prong toggle, marine grade, see if you can googley it. $5 tops I'm thinking. Will you buy me dinner with the money you save? |
Posts: 206 Lumber Bridge, NC United States | http://www.amazon.com/Crazycity-SPST-Rocker-Switch-Neon/dp/B00K2NTC...
?s=boating-water-sports&ie=UTF8&qid=1402013090&sr=1-2
Posts: 1066 Peru, IN | varyder - 2014-06-05 1:26 PM what? are you sure it's just a switch? It's a three prong toggle, marine grade, see if you can googley it. $5 tops I'm thinking. But will the generic replacement have that Hazard Warning Light symbol on it? How ya gonna know which switch is which?  |
| Otto is the OE supplier and supplies these switches with all kinds of configurations. If you go to this page and use the Part Builder you can configure what you want including LEDs, etc. At the bottom of the page will be the built up part#. Now the only issue will be to find a distributor to order it from but I doubt if that will be too difficult. Here is the page:
http://www.ottoexcellence.com/products/k1-sealed-rocker/
Marc |
| You can get the switches any way you want straight from the manufacturer, even with the hazard signal. I can't remember who the manufacturer is at the moment, but I think it's listed on the switch. If not, google the number on the switch housing and you should get the name. I looked at them once, and they have all kinds of options for that type of waterproof switch. DAMN, can't find who that was, but I'm sure I found if from the info on the switch housing. |
| OTTO - K1
Download the datasheet and you can see all the options. |
| It has to be the switch as when I bypass the switch with wires the hazards work.
Thanks for the help. |
| Sure varyder!
Drop by and go for a cruise. but first check weather where I live. It is 2C = 35.6F this am on my way to work. Love heated gear!
Edited by boatsrfun 2014-06-06 6:00 AM
| If you purchase from Otto they have a $25.00 minimum, I ordered a couple of switches momentary contact from them and I ended up with two extras. Was planning on wiring my garage door actuator to the momentary on switch on the console.
