Posts: 309 Vineland, NJ United States | what is best way to remove the retaining clip for passenger floorboards. |
Posts: 8144 New Bohemia, VA | small, very small, flat tip screw driver |
Posts: 206 Lumber Bridge, NC United States | replace the pins with shoulder bolts. my clips popped off during a ride and the pin was half way out when I looked at the peg getting back on the bike. the groove on the pin is to shallow to hold the clip. |
| do not re use pin it will not hold. Go to hardware with pin and ask for "C" clip |
Posts: 1066 Peru, IN | Too bad there's not a rear tip over withOUT the mounting boss for the rear floorboard. I NEVER have a pillion and don't like the looks of the rear boards. I took the trunk off and I think, without those, it would look more streamlined. I've thought about buying a used set of rear tip overs and cutting the mounting bosses off then repainting them. |
